From the definition of spectral calculus, I want to verify whether the following operator identity is actually correct:
$$ (-1)^{\frac{1 + \sigma^z}{2}} = \sigma^z $$
This expression involves raising a number $-1$ to an operator exponent — which is not generally defined in operator algebra — unless we interpret it via functional calculus, specifically the spectral theorem.
Let me outline what I believe is the intended meaning.
We define the function $$ f(\sigma^z) := (-1)^{\frac{1 + \sigma^z}{2}} $$ using the spectral theorem. That is, for any state $|\psi\rangle$ that is an eigenstate of $\sigma^z$, with eigenvalue $\lambda \in \{+1, -1\}$, we define: $$ f(\sigma^z) |\psi\rangle = f(\lambda) |\psi\rangle. $$
So:
- $f(+1) = (-1)^1 = -1$
- $f(-1) = (-1)^0 = +1$
Hence, $$ (-1)^{\frac{1 + \sigma^z}{2}} = -|\uparrow\rangle \langle \uparrow| + |\downarrow\rangle \langle \downarrow| = \sigma^z. $$
My questions are:
- Is this identity indeed correct under the rules of spectral calculus?
- Is this a valid application of the spectral theorem even though the function $f(x) = (-1)^x$ is not analytic (i.e., not expandable as a power series)?
- Are there any subtleties in applying spectral calculus to such functions — particularly when they’re defined only on the spectrum of the operator?
I'm looking for a mathematically precise explanation — either confirming the identity or pointing out any caveats I should be aware of.
