I am unfamiliar with quantum optics and have recently been struggling to evaluate some expectation values involving squeezed states. Any help and guidance would be greatly appreciated!
The matrix elements I am considering boil down to the following form.
$$ \langle \Psi_1| \exp\left(\sum_{mk}\beta^*_{mk}b_m b_k\right) \text{($b$ ..$b^\dagger$..)} \exp\left(\sum_{ln}\beta_{l-d, n-d} b^\dagger_l b^\dagger_n\right)|\Psi_2\rangle $$
where $|\Psi_1\rangle$ and $| \Psi_2\rangle$ are coherent states defined as follows.
$$ |\Psi_1\rangle = \exp\left(\sum_j \xi_{j} b^\dagger_m - \text{h.c}\right)|0\rangle $$
$$ |\Psi_2\rangle = \exp\left(\sum_j \xi_{j-d} b^\dagger_m - \text{h.c}\right)|0\rangle $$
Here the indices $m,k,l,n, j$ are cyclic mod $N$ and $d$ refers to some constant shift of the indices. $\beta_{mk}$ can be assumed to be symmetric $(\beta_{mk} = \beta_{km})$.
Usually my strategy with coherent state expectation values has been to normal order the operator string sandwiched between the bra and ket and to act these directly onto the coherent states to the right or left. However, I have been unable to use this naive approach in evaluating the above matrix element.
Does the type of expression above have a closed form? If so, what would be the most convenient or clearest way of obtaining closed form expressions of the expectation value? I have been looking at some so called disentangling formulas and so forth but they remain pretty opaque to me at the moment.
