In Arnold's Mathematical Methods of Classical Mechanics, a theorem is given (part III, Ch.9 , p.247) stating that the trajectories of a system with potential $V(x)$ and total energy $E$ are geodesic lines of the conformally flat metric given by:
$$ g_{ij} = (E - V(x))\delta_{ij} .$$
I tried verifying this by explicitly deriving the geodesic equation: from the definition of the Christoffel symbols we get
$$\Gamma^i_{kl} = \frac{1}{2}\frac{1}{E-V(x)} \left( -\delta_{ik}\partial_l V -\delta_{il}\partial_k V + \delta_{kl}\partial_i V\right)$$
so the geodesic equation is
$$ \ddot x^i = -\Gamma^i_{kl} \dot x^k \dot x^l = \frac{1}{E-V(x)}\left( \partial_k V \dot x^k \dot x^i - \frac{1}{2} \partial_i V \dot x^k \dot x^k \right)$$
or in vector notation
$$ \ddot x = -\frac{1}{E-V(x)}\left( \frac{1}{2}|\dot x|^2 \nabla V(x) - \dot x(\dot x \cdot \nabla V(x))\right).$$
(A similar derivation can be found in the answer to this question).
Now if my understanding of the theorem is correct, trajectories with total energy $E$ (i.e. $x(t)$ satisfying $\ddot x = -\nabla V(x)$ and $\frac{1}{2}|\dot x|^2 + V(x) = E$) should satisfy this geodesic equation. The problem is that this seems to hold only if the second term vanishes, namely if $\dot x$ is perpendicular to $\nabla V(x)$ - in that case $\frac{1}{2}|\dot x|^2$ cancels the $E-V(x)$ in the denominator and we get the desired $\ddot x = -\nabla V(x)$. But clearly there are trajectories for which this is not the case. For example if $\dot x$ is parallel to $\nabla V(x)$ (such as radial trajectories in a spherically symmetric potential), we have $\dot x(\dot x \cdot \nabla V(x)) = |\dot x|^2 \nabla V(x)$ and the equation becomes $\ddot x = + \nabla V(x)$ which is clearly wrong.
What am I missing?
J. Delaney
  • 2,680
  • 15
The question was probably formulated in response to a previous answer of mine.
It is normal that you are struggling to recover the original equation of motion: $$ \frac{d^2x}{dt^2} = -\nabla V, $$ because it is not possible. In the new system, your Lagrangian is: $$ L = \frac12(E-V)\left(\frac{dx}{ds}\right)^2 $$ but the time is not the same as the original one. As a sanity check, you can compare the conserved quantity. In the mechanical system, it is: $$ \frac12\left(\frac{dx}{dt}\right)^2+V = E $$ while for the geometric system, it is rather: $$ \frac12(E-V)\left(\frac{dx}{ds}\right)^2= 1. $$ You therefore need to rescale appropriately: $$ ds = (E-V)dt. $$ You can check this explicitly from the geodesic equation: $$ \frac{d^2x^k}{ds^2} +\Gamma_{ij}^k\frac{dx^i}{ds}\frac{dx^j}{ds}= 0 $$ It is actually faster to start from the Euler Lagrange equations (from which you deduce the Christoffel symbols in the first place): $$ \frac{d}{ds}\left((E-V)\frac{dx}{ds}\right)-\frac12\left(\frac{dx}{ds}\right)^2\nabla(E-V) = 0 \\ (E-V)\frac{d}{ds}\left((E-V)\frac{dx}{ds}\right) = -\frac12(E-V)\left(\frac{dx}{ds}\right)^2\nabla V \\ \frac{d^2x}{dt^2} = -\nabla V. $$ This is how you recover the equivalence between the mechanical system and the geometric system. As usual, the fastest way to recover the equivalence is to use the hamilton-Jacobi equation, where the time rescaling appears naturally without having to parachute it beforehand.
Hope this helps.
LPZ
  • 17,715
  • 36
  1. OP is considering the "Jacobi form of the abbreviated action/Maupertuis principle," $$\begin{align} S[q]~=~& \int p_k dq^k ~=~\int\!\frac{\partial T}{\partial\left(\frac{dq^k}{dt}\right)} \frac{dq^k}{dt}dt~=~\int\! 2Tdt\cr ~=~&\int\! \sqrt{2T}d\rho~=~\int\! \sqrt{2(E\!-\!V(q))}d\rho\cr ~=~&\int\! ds~=~\int\!d\lambda\sqrt{g_{ij}(q)\frac{dq^i}{d\lambda}\frac{dq^j}{d\lambda}} , \end{align}\tag{1}$$ where we have introduced 2 metric tensors$^1$ $$\begin{align}g_{ij}(q)dq^idq^j~=~(ds)^2~:=~&2(E\!-\!V(q))(d\rho)^2, \cr (d\rho)^2 ~:=~&m_{ij}(q)dq^idq^j,\end{align}\tag{2}$$ cf. Refs. 1 & 2.
  2. It is tempting to consider an extended action $$ \widetilde{S}[q,e]~=~\int\!d\lambda\left(\frac{1}{2e}m_{ij}(q)\frac{dq^i}{d\lambda}\frac{dq^j}{d\lambda}+e(E\!-\!V(q))\right),\tag{3}$$ where $e>0$ is an einbein field. If we integrate out/eliminate the $e$ field, we return$^2$ to the square root action (1).
    The action principles (1) & (3) have world-line (WL) reparametrization gauge symmetry$^2$ $$ \begin{align}\lambda\qquad\longrightarrow\qquad\lambda^{\prime}~=~&f(\lambda),\cr e(\lambda)\quad\longrightarrow\quad e^{\prime}(\lambda)~=~&\frac{e(\lambda)}{\frac{df(\lambda)}{d\lambda}},\end{align}\tag{4}$$ which seems to be the root of OP's question. The stationary action principle (with its Euler-Lagrange equations) corresponds to the gauge $e=1$.
References:
  1. V.I. Arnold, Mathematical methods of Classical Mechanics, 2nd eds., 1989; p.247.
  2. H. Goldstein, Classical Mechanics; eq. (8.89).
$^1$ Ref. 1 uses the opposite notation for $ds$ and $d\rho$. OP assumes that the mass metric $m_{ij}(q)=\delta_{ij}$.
$^2$ This is similar to the relativistic point particle, cf. this & this Phys.SE posts.
