I'm familiar with Lagrangian mechanics and Newtonian mechanics, though I'm currently building an intuition for the concept of "action" or "least action" (i.e what unites the two theories). The principle of least action, as formulated by the Euler-Lagrange theory is generally what comes to mind for me.
$$\frac{d}{dt}\frac{\partial L}{\partial \dot q_k}-\frac{\partial L}{\partial q}=0.$$
However, I've recently learned how this theory came to be through a Veritasium video.
If "action", or $$S_0=\sum mvs$$ is such a useful concept, as put by Maupertuis, then why is it not taught in lower level physics? The intuitive gap b/w energy or force and action would seem to be the reason.
If one differentiated action in time, you might arrive at the concept of Vis Visa, and its corollary energy/work.
$$\frac {d}{dt} S_0 = \frac{d}{dt} \sum mv(t)s(t)=\sum mas + \sum mv^2=W+2T.$$
Wouldn't that make action just work performed over a given time interval and the sum of the energy over that same interval? That doesn't seem to be much of a different concept from force over a given distance, or energy conservation within a given system. Perhaps the difference is more semantic than anything. We've decided force, momentum, and energy are meaningful concepts. Action might just confuse the matter for new learners.
Anyone have a good intuition for action, and the principle of least action, that I'm missing here? Some help would be really appreciated.
  1. On one hand, in the principle of stationary action/Hamilton's principle $$ \delta \int_{t_i}^{t_f}\! Ldt~=~0, \tag{1}$$ the initial and final times $t_i$ and $t_f$ are kept fixed, while the total energy $E$ is free.
  2. On the other hand, in the abbreviated action/Maupertuis' principle $$ \delta \int_{t_i}^{t_f}\! p_k dq^k~~=~0, \tag{2}$$ the total energy $E$ of all paths is kept fixed and the same; while the initial and final times $t_i$ and $t_f$ are free.
TL;DR: The variational principle (1) is more important in physics and its applications as compared to (2), which is why (2) is typically not taught in lower level physics.
  • For a more rigorous derivation and generalization of the argument $2\Rightarrow 1$ given in the Veritasium video at 21:00, see e.g. my Phys.SE answer here.
  • For more information about the relationship $1\Leftrightarrow 2$, see e.g. my related Phys.SE answer here.
It is indeed the case that there is a close relation between Hamilton's stationary action and the work-energy theorem. Both Hamilton's stationary action and the work-energy theorem are stated in terms of kinetic energy $\frac{1}{2}mv^2$ and potential energy. Just from that we can already be sure that there must be a connection.
In this answer I first provide some historical context. After that I will discuss the relation between Hamilton's stationary action and the work-energy theorem.
At the time that Hamilton published Hamilton's stationary action, which was in 1834, the work-energy theorem had not been formulated yet.
Formulation of the work-energy theorem happened somewhere in the 1850's, so that was two decades later. It was only then that there was opportunity to recognize the relation. There is a Nov. 2023 answer by me with a derivation of the work-energy theorem from F=ma
Prior to the 1850's physicists used the concept of 'vis viva', the living force, defined as $mv^2$
(Other than the concept of vis viva there was also the concept of vis inertiae. Vis inertiae was associated with the fact that a force is required to set an object into motion. Vis viva was associated with the notion that a moving object is hard to slow down; it tends to persevere in its motion.)
The shift that put the concept of energy in a central position was to replace the concept of living force with kinetic energy: $\frac{1}{2}mv^2$
The work-energy theoren narrows down the choice for the value of kinetic energy to $\frac{1}{2}mv^2$. The work-energy theorem is applicable when the force that is involved is a conservative force. (A force is categorized as a conservative force if it has the property that the potential difference betweeen two points is independent of how you move from one point to the other.) The work-energy theorem has the following implication: the sum of kinetic energy and potential energy is a constant.
$$ E_k + E_p = Constant \tag{1} $$
(Presumably: one of the reasons that prior to the 1850's the notion of conservation of energy wasn't recognized yet was that with living force, $mv^2$, the sum of living force and potential energy is not a conserved quantity. Physicists did use, of course, that living force $mv^2$ and potential energy always transform into each other in the same ratio. But they always had to include that factor 2.)
Lagrange's great work, Mécanique Analytique, was published in 1889. So that is more than four decades prior to the introduction of Hamilton's stationary action.
At the time of composing Mécanique Analytique the only available action concept was Maupertuis' action. In Mécanique Analytique Lagrange did not use Maupertuis' action. Lagrange explains why he decided against using Maupertuis' action. Lagrange was of the opinion that Maupertuis' action was a corollary of the laws of motion rather than a principle.
An english translation of Mécanique Analytique is available on archive.org.
Link to that file and an extensive quote from Lagrange is available in an answer by me on the History of Science and Mathematics stackexchange, in which I give quotes from Hamilton and from Lagrange on their opinion about action concepts
My preferred way to think about Hamilton's stationary action is to think of it in terms of its two components:
-time integral of the kinetic energy
-time integral of the potential energy
Differentiation and integration are linear operations. That means that we can rearrange order of operations; the outcome remains the same.
Taking the derivative of Hamilton's action can be thought of as taking the derivative of each constituent integral separately. The two components respond to variation individually.
The true trajectory corresponds to a point in variation space such that the response of the kinetic-energy-integral matches the response of the potential-energy-integral. When the two responses match the derivative of Hamilton's action is zero.
As we know: we have in describing motion in terms of energy another instance of matching rate of change: if we track kinetic energy and potential energy over time: the rate of change of kinetic energy matches the rate of change of potential energy.
In the following I will describe how to make the connection between those two instances of matching rate of change.
About integration and derivative of a curve:
As example I take the following curve: an inverted parabola from x=-1 to x=1 $$ y(x) = -x^2 + 1 \tag{2} $$ Integrate with respect to x, and then evaluate the derivative of that integral with respect to variation in the y-direction.
Next: increase the slope of the curve by a factor of 2: $$ y(x) = -2x^2 + 2 \tag{3} $$ Compared to (3): the derivative of the integral of (3) is twice as large as the derivative of the integral of (2).
The above relation, presented in example form, generalizes to all curves:
For any curve: the derivative (wrt to y-coordinate) of the integral $\int dx$ of that curve increases in linear proportion to the slope of the curve.
Now we see how that works out for Hamilton's stationary action: We have:
satisfying the condition that the derivative of Hamilton's stationary action is zero means satisfying the condition that the derivative of the kinetic-energy-integral matches the derivative of the potential-energy-integral.
That means: for a true trajectory: in a diagram where kinetic energy and potential energy are plotted as a function of time the slope of the kinetic energy curve will match the slope of the potential energy curve.
Matching slopes means:
$$ \Delta E_k + \Delta E_p = 0 \tag{4} $$
This relation is bi-directional: if the slopes of the energy curves are matching then it follows that the derivatives of the corresponding integrals are matching.
Co-changing versus counter-changing
When variation is applied to a trajectory the corresponding kinetic-energy-integral and potential-energy-integral are co-changing. By contrast: as an object moves along a trajectory the kinetic energy and potential energy are counter-changing.
In the Lagrangian of classical mechanics, $(E_k - E_p)$, the minus sign is there because in response to variation the two integrals are co-changing. When two things are co-changing: for comparison subtract one from the other.
In actual motion the kinetic energy and potential energy are counter-changing, hence the sum of $E_k$ and $E_p$ is a constant:
$$ E_k + E_p = Constant $$
The above reasoning is worked out mathematically in a July 2024 answer by me about Hamilton's stationary action
The key points:
It is very useful to think of Hamilton's action in terms of the two constituent components:
-kinetic-energy-integral
-potential-energy-integral
The true trajectory has this property: $\Delta E_k + \Delta E_p = 0$
Hamilton's stationary action expresses that property: matching rate of change.
Cleonis
  • 24,617
