A naive question about nuances on meaning of the concept frame of reference and how much "intrinsically physical" information it carries about considered physical system.
To my knowledge (compare with this )naively a frame of reference is a priori a mathematical - so unphysical - procedure (because it explicitly depends on making choices) based on specifing a frame, so a picking a set of basis vectors in order to fix a welldefined coordinate system describing my given physical system or a part of it we would like to model (eg if we a dealing with "whole" system modeled inside laboratory frame and pick a relative frame of reference wrt a picked moving partial system where this object is inert).
Eg, think of priciple of gauge theory where gauge trafos swap between mathematically a priori different but physically identical configurations; keyword: invariance of laws of physics under certain trafos.
For instance a toy example, assume we pick laboratory frame (with basis $e_1=(1,0,0), e_2, e_3$ analogously in 3d where the observer stands in (0,0,0) and observes a car passing parallel to $e_1$ through point $(1,1,0)$ with constant velocity $\vec{v}=v \cdot e_1$.
Then the car's frame of reference (ie where it stays stationary at $(0,0,0)^C$ with resp car's frame of reference) is given by Galilei trafo as $e^C_1(t):=(v \cdot t,0,0), e^C_2=e_2, e^C_3= e_3$
(Note, $e_i=e_i(t)$ can clearly be time dependent)
So my understanding of a frame of reference is that as it technically corresponds to just picking a basis spanning the number of degrees of freedom of the considered physical system we are going to describe: Once we have picked frame of reference, we can model the system with respect associated coordinate system.
So at all it seems to me that picking such a frame of reference inducing coordinate system modeling my physical system is a pure mathematical construction, isn't it?
On the other hand it seems (see this question & discussion that it may be possible that a physical system may have a so called "privileged frame of reference", which seems to be an "intrinsically physical" feature of the considered system. The example there was based on an attempt to take a putative discrete spacetime & which principles would going consequently to be violated.
Therefore I have two questions:
(1) A naive one: As I elaborated above it seems so far to me that the "choice" of a frame of reference is an "unphysical" procedure as as one picks a mathematical object (a basis) to model a physical system. How can a frame of reference be "(physically) privileged"? So is essentially a frame of reference a purely mathematical construction or can it cary intrinsically physical information of the system? For instance, I could rechoose a new basis by eg rotating or shifting to old one without "changing the physics".
The issue in linked tread strongly suggests that my understand behind "physical nature" of frame of reference is wrong; namely that is not a pure mathematical construction& basing on unphysical choices.
Could somebody clarify that part how much physics really sits in concept of frame of reference?
(2): Having the problem discussed in linked question in mind: Why discrete structures (as eg there the putative discrete spacetime) tend to have a "privileged frame of reference", ie that it has a "distinguished" frame of reference reflecting intrinsically physics of the system. Is there a striking reason for this?
I noticed similar question but which not adresses exactly my concern.
