15
In wikipedia, regarding this topic, different examples are given as to why a reference frame and coordinate system are NOT the same thing (https://en.wikipedia.org/wiki/Frame_of_reference). Example from J.D Norton:
More recently, to negotiate the obvious ambiguities of Einstein’s treatment, the notion of frame of reference has reappeared as a structure distinct from a coordinate system.
I am trying to understand the different definition and I have come up with the following understanding, for which I want to know whether is correct or faulty.
First off all I consider that a difference between the two exists. For once a coordinate system is a mathematical/abstract concept while the reference frame is something grounded in physics/or physical.
I would consider a coordinate system of whatever kind as "tool" (for lack of better words), which assigns a set of numbers to each point in space.
The reference frame is an "entity" (for lack of better words again), which is correlated or related to a physical location/body etc, to which a coordinate system of whatever kind is attached to, giving to the observer, in this physical location (one can say the observer is at rest in this reference frame) the possibility to assign a location and a time to an event E.
imbAF
  • 1,912
  • 13
  • 30
5 Answers5
18
It is very important to recognize that different authors may use the same term differently. I have seen at least three different meanings of the term “reference frame” in different sources:
  1. some authors treat the term “reference frame” as a synonym for “coordinate system”, sometimes with the implication that it is restricted to coordinate systems with one timelike coordinate three spacelike coordinates.
  2. other authors use the term “reference frame” to refer to a tetrad. Again usually that is restricted to a tetrad with one timelike vector field and three spacelike vector fields, and often with the further requirement that the vector fields be orthogonal and normalized.
  3. yet other authors use the term “reference frame” to refer to a collection of rods and clocks or other physical devices used for measuring time and position. These are automatically timelike and spacelike respectively, and often orthogonal.
I would not try to take a very rigid stance on the meaning of the term. Simply find out how an individual author is using it. Also, if there is any ambiguity, then simply clarify how you are using it. It is simply a choice of definition, so there is no particular right or wrong answer. But when people don’t clarify their usage it can lead to confusion
Dale
  • 117,350
Indeed, it is helpful to distinguish these two concepts.
Coordinate System
For whatever phenomenon you want to describe, be that a particle or a field, a set of coordinates $(x_1,...,x_n)$ must be chosen. Once you've done that, there is an unlimited number of arbitrary transformations $(x_1,...,x_n)\rightarrow(y_1,...,y_n)$ you could do to represent evertyhing in another coordinate system. You don't need to invoke any laws of physics to do this, it's simply a mathematical construct. A typical example is the transformation from Cartesian Coordinates to Polar Coordinates.
Reference Frame
It's customary for physicists, since Einstein, to define something by defining its relations to something else. That's why, to define what a reference frame is, we define the transformations between different reference frames.
A reference frame transformation is a coordinate transformation, this simply means that there is a mathematical transformation which can translate someone's observation to another person, at some other position and time. However, it's a special transformation that cares about physics.
The way to include physics in reference frame transformation is that We usually make someone (perhaps unwillingly) ride a spaceship away from you, at very high speed, and compare our observation of the same stuff. The game is for you to observe the phenomenon, and at the same time guess what the other person will observe. This is a coordinate transformation, but you cannot just make up any coordinate transformation, it's a special one related to where the other person is, how fast he is moving, and so on...... In this way, if you correctly guess what the other person observes, you can confirm your believe about certain physical laws( Energy, momentum, how to add speed, is Newton's law right?....), or perhaps change your laws such that it satisfies this strange coordinate transformation, which is based on our believes and experiments on real physics. This is what special relativity is doing, in a nutshell.
Liuke LYU
  • 990
I concur with the answer by contributor Dale; I upvoted.
Indeed when you read an author it is necessary to reconstruct (from context) how that author is using the expression 'frame of reference'.
Indeed when you use the expression 'frame of reference' yourself it is up to you to make sure that the reader is aware of how you are using it. You must either define explicitly, or you must provide context such that the reader can infer what meaning you are using.
Personally I have stopped using the expression 'frame of reference' altogether. There is nothing intrinsically wrong with that expression, but there is so much variance in how it will be understood that it's just not a dependable intrument for communication.
That leaves the expression 'coordinate system'. Of course, the expression 'coordinate system' is rich with connotations. When using the expression 'coordinate system' in writing I have to be aware of that.
A prominent connotation is that a coordinate system has a zero point. So: when I feel it's necessary to counterplay that connotation I will refer to 'the equivalence class of inertial coordinate systems', instead of to 'an inertial coordinate system'. The members of the equivalence class of inertial coordinate systems all have a different zero point; at the same time all those class members stand in a well defined relation to each other; it's quite an exclusive class.
My assessment is that by not using the expression 'frame of reference' I put myself in a position that allows me to express myself with more clarity.
Reference:
I acquired the expression 'equivalence class of inertial coordinate systems' from Kevin Brown's website Mathpages.com, from the article A primer on special relativity
Cleonis
  • 24,617
I personally think of a reference frame as being a velocity and position in space from which to observe things, and a coordinate system as being the measuring system by which we locate things at other positions. It matches the general usage of the terms better.
Essentially, the reference frame describes here, while the coordinate system describes everywhere else with respect to here.
Note phrases like this (from IsaacPhysics.org) that are quite common:
The different observations occur because the two observers are in different frames of reference.
You can't be in two different coordinate systems. You can be at different locations, or have different velocities, in a single coordinate system. You can use different coordinate systems. But both observers are in locations, at velocities, described by both coordinate systems.
That snippet is followed by the definition:
A frame of reference is a set of coordinates that can be used to determine positions and velocities of objects in that frame; different frames of reference move relative to one another.
This essentially defines a reference frame as a coordinate system, but that doesn't make sense in context. It says a reference frame is something that can move. A coordinate system spans all of spacetime, but something that moves needs a finite space it occupies so we can locate it and therefore determine it's moving. The thing that's moving is the origin of the coordinate system.
  1. A reference frame is something that moves. The origin of a coordinate system moves.
  2. An object can exist in one reference frame while not existing in another. Two coordinate system origins can be at different locations, moving at different speeds.
The usages of "frame of reference" in the quotes above are satisfied by calling it the origin of a coordinate system. But they're not satisfied by calling it a coordinate system, since an object can't exist in one coordinate system but not the other, and coordinate systems don't really have locations as they span everywhere.
The origin of a coordinate system is a position and velocity in space that we use to calculate how other objects would look from said origin, leading to the simple definition I gave above:
A reference frame is a velocity and position in space from which to observe things.
Side note 1: we don't have to use the origin. We could substitute "origin" with "specific location", since all the locations within a coordinate system can move like the origin, and an object can be in one location in one coordinate system and not be at a specific location in another coordinate system. But it's generally simplest to use coordinate systems whose origins are located at the point from which we want to view things.
Side note 2: "position" here includes rotational orientation as well as linear position.
MichaelS
  • 2,223
Reading this topic this is what I could come up with A coordinate system a mathematical means of expressing the projected positions of points on various surfaces.
A reference system is the practical realization of the reference systems through observing the designed monuments to come up with a set of coordinates. This means that with the aid of the reference frames, the geodetic reference systems can be realized and made usable.
