Can a quantum measurement be made undone, so that the original superposition reappears? Let me illustrate my question with an example.
Consider the Schrödingers cat thought experiment, in which the cat in the box is in a superposition $\frac12\sqrt2(|\mathrm{dead}\rangle + |\mathrm{alive}\rangle)$. When I open the box, the system collapses into one of the two states; let's say it is $|\mathrm{alive}\rangle$. Now suppose that I completely forget the result of the experiment, remove all data about the cat from my lab, and close the box. If I succeeded in reversing the measurement, the state of the cat would again be $\frac12\sqrt2(|\mathrm{dead}\rangle + |\mathrm{alive}\rangle)$. However, I am not sure if this is the possible, because the cat state did collapse at some point. Has the cat been reduced to a 'classical' uncertainty, where the cat is dead or alive with probability 0.5? Or can I really invert the measurement and recreate the superposition?
