To better understand how gravity and movement works, a common question is to ask where an apple would land if dropped from the top of a mast on a moving boat (let's assume a boat with a motor but with a mast, and no wind blowing apart from the relative speed of the boat, and a constant speed, let's say 50km/h, it's a fast boat).
People often mistakenly answer it would land on the rear of the boat, because the boat is still advancing forward while the apple is falling straight down.
So it is explained that there is a conservation of movement, and the apple was moving at the same speed as the boat, and hence it would land at the base of the mast, and it is often added that it's the same case as if you jump on a moving train, you don't end up at the rear of the train, but instead land where you were before.
However it seems to me that those 2 examples are not the same. On a train, the compartment is closed, so the air is trapped and also moves with the train. With the boat case, there is no close environment, so as soon as it gets dropped, it loses contact with the boat and stops being accelerated by the boat motors (that counteract the water/air slowing it down, so that it maintains a constant speed), so starts being slowed down by the air around it.
Assuming a 20m mast, I think it takes roughly 2s for the apple to reach the boat, and I'd say that in 2s, the air has ample time to slow the apple enough so that it doesn't fall on the bottom of the mast, but rather closer to the rear of the boat. Am I wrong? How far would the apple land (if there's not enough numerical values, feel free to take any reasonable choice)?
