As I understand it, there are a few different massless particles. Is there anything that differentiates these from each other besides frequency/wavelength?
My definition of speed would be the time it takes to get from one place to another. If we say nothing moves faster than light, we therefore mean that light will go from here to there (the Sun to the Earth for instance) in less time than any other particle.
When thinking about speed related to wavelength, I picture two people. The first person is running on a flat surface, the second is running up hills, and there is a set finish line. If both people run at the same speed, at the end of a certain time frame both will have run the same distance, but the person running on a flat surface will be closer to the finish line. In a race from the Sun to the Earth, the person (massless particle) with the flatter path (smaller wavelength) would arrive first. Is this a misunderstanding on my part?
Is the reason we use light as the limit that light has the shortest wavelength of the massless particles? If so, is it possible we could discover a massless particle with a shorter wavelength that would be faster? If not, what differentiates these massless particles?
