I am currently taking a class on Quantum Field Theory. The propagator was defined as:
$$K(x,t;x',t') = \langle x|\hat{T}e^{{\frac{-i}{\hbar}\int_{t}^{t'}dtH(t)}}|x\rangle$$
where, $\hat{T}$ is the time ordering operator. I fully well agree with this so far. However, we next considered '$n$' time slices (which is later considered to approach infinity) and equated:
$$\hat{T}e^{{\frac{-i}{\hbar}\int_{t}^{t'}dtH(t)}} = e^{{\frac{-i}{\hbar}\int_{t_{n-1}}^{t'}dtH(t)}} e^{{\frac{-i}{\hbar}\int_{t_{n-2}}^{t_{n-1}}dtH(t)}}... e^{{\frac{-i}{\hbar}\int_{t}^{t_1}dtH(t)}} \tag1$$
The argument given for this was, "Due to time ordering we now have all operators at later times to the left of earlier times". I do not fully agree with this because I believe in order to use the identity $e^{A+B} = e^Ae^B$, we need to have $[A,B]=0$. Here, our Hamiltonian does not necessarily commute with itself at different times.
However, texts I have looked up, seem to fully ignore time-dependent Hamiltonians and instead use time-independent Hamiltonians.
So my question is: How do I properly deal with the derivation in the case of a time-dependent Hamiltonian? Is eq(1) after all correct? What Am I missing?
Sancol.
  • 960
ofbrakets
  • 132
They do commute at different times under the time ordering symbol. To see this, $$ T[H(t_1),H(t_2)] \\= T[H(t_1)H(t_2)-H(t_2)H(t_1)]\\=\begin{cases} H(t_1)H(t_2)-H(t_1)H(t_2) & (t_1 >t_2) \\ H(t_2)H(t_1)-H(t_2)H(t_1) & (t_2 > t_1) \end{cases} \\=0$$
So you can ignore the extra terms from the BCH formula and split the exponentials. After you do this (and your $\Delta t$ intervals are small enough) you can drop the time ordering because you've already written this expression in a manifestly time ordered way. This gets you all the way to your Equation 1.
11zaq
  • 1,224
This is because by definition the operator-ordering (in this case time-ordering $T$) takes symbols/functions to operators; not operators to operators.
Before its evaluation, symbols/functions within its argument supercommute. After the operator-ordering procedure has been applied, the result consists of possible non-commutative operators.
See also this and this related Phys.SE posts.
