I am thinking about the problem, "Why does a group of charges with spherical symmetry, where each oscillates radially while retaining spherical symmetry, not radiate?" I figured out that with a spherically symmetric charge distribution, there only exists a monopole scalar potential which is time-independent. However, I do not have any clue about what spherical symmetry implies for the magnetic vector potential. Can anyone give me some ideas about this?
Radiation would have to be spherically symmetric. Both the E and B vectors would have to be radial. Suppose either had a tangential component at some point. If you rotate the system around the axis through that point and the center, everything should look the same. You should also see a component in the rotated direction. You can't have two non-zero tangential vectors at the same point. The tangential component has to be zero.
But that means E and B are parallel. That isn't possible for radiation.
mmesser314
  • 49,702
