I am interested in solving the dual (adjoint) Lindblad master equation for a time-dependent operator $O(t)$ as follows \begin{equation} \dot{O}(t) = i[H, O(t)]+\sum_{\alpha\in I} L_\alpha ^\dagger O(t) L_\alpha -\frac{1}{2}\left\{L^\dagger_\alpha L_\alpha, O(t)\right\} \end{equation}
where the Hamiltonian $H$ is quadratic in fermionic operators, the jump operators are linear and have the form $L_\alpha = \sqrt{\gamma}c_\alpha$, $c_\alpha$ is the fermionic field, $\gamma$ is the decay rate and $I$ is a set of indices.
In particular, I am interested in the dynamics of $O(t)=c^\dagger_j(t)$ for some index $j\in I$, because I am actually interested in computing the two-time correlator $<c^\dagger(t)_j c_i(0)>$.
I know that the Lindbladian is linear in the reduced density matrix of the open system, so I expect the dual (adjoint) Lindbladian to be linear in the operator $O(t)$ too.
My question is, owing to this supposed linearity - which I expect leads to a linear differential dual Lindblad equation - whether it is possible, in principle, to write the solution of this equation as a linear combination of the fermionic operators at time $0$, i.e., \begin{equation} c^\dagger_j(t)= \sum_{\alpha\in I} V_{j,\alpha}(t)c^\dagger_\alpha(0) \end{equation}
If this was true, the two-time correlator might be easily written as \begin{equation} <c^\dagger_j(t)c_i(0)> = \sum_ {\alpha\in I} V_{j,\alpha}(t)<c^\dagger_\alpha(0)c_i(0)> \end{equation} and I could be able to retrieve the form of $V(t)$ from the equation of motion of the this two-time correlator.
I am not sure about this possibility since I am not able to retrieve explicitly the form of the matrix $V$ owing to the presence of the anticommutator in the Lindbladian, which prevents me from simplifying the expression of the dual equation as it can be done in the Heisenberg equation of closed systems. Furthermore, what confuses me is the fact that the operator $c^\dagger_j$ is also involved in the sum of the Lindbladian, even if in a time-independent way.
In short, is the dual Lindblad equation actually linear in the sense I am writing or am I lacking some theoretical information concerning linearity? I would be glad if you could provide some references as well.
