If one starts with a flat piece of paper, removes a wedge, and tapes the paper together, you get a cone. The angle of the removed wedge is called the "angular deficit".
Now if this is done in 3 spatial dimensions, removing a 'wedge' along an entire line, there is similarly an angular deficit around the line defect. Using cylindrical coordinates we can write the spacetime metric as:
$g^{\mu\nu} = dt^2 - dz^2 - dr^2 - r^2 d\theta^2$
with $0 \leq \theta \leq 2 \pi - \Delta \phi$ and the boundary condition that $\theta=0$ is equivalent to $\theta = 2 \pi - \Delta \phi$, where $\Delta \phi$ is the angular deficit. This line defect is sometimes referred to as a 'cosmic string'. In GR this can also be used to describe the spacetime outside of a cylindrically symmetric object in certain conditions ( http://prd.aps.org/abstract/PRD/v39/i4/p1084_1 ).
Besides the change in boundary condition for $\theta$, this looks exactly like flat spacetime. So the spacetime is locally flat (the Riemann curvature vanishes) everywhere except at the line defect where it is undefined. So without observing the defect directly, its gravitational presence can only be seen in a topological sense as it requires measurements of paths going around the defect.
To make sure my intuition is okay up to this point, first I'd like to verify that last line:
In case I'm missing something... In such a spacetime, is it possible to somehow measure the angular deficit "locally" or using paths that have a zero winding number around the defect?
This intuitive understanding of angular deficit seems to implicitly require that spacetime is locally flat and have the symmetry of an infinite cylinder. For example, if I broke translation symmetry along the line defect by making it finite in length, one can't even use intuitive topology to state whether a path went 'around' the line defect or not. However, physical intuition states that spacetime around the center of the finite line defect, at distances much less than the finite length, should still approximate the infinite line case.
Can "angular deficit" along a path be rigorously defined for arbitrary metrics somehow? If not, what symmetries are necessary to do so?
