I am unclear about what is meant by spin quantum number being an inherent number. I understand the spin quantum number can either be +1/2 or -1/2.
So, we can think of the spin quantum number like a arrow pointing upward or downward, and it always have the same magnitude.
What I am unclear about is this: Can there be a transition from spin up state to spin down state, or vice versa?
If a such a rotation/transition can occur, does that necessarily mean that it is the only magnitude of the spin quantum number that is intrinsic, and not the direction of it?
It depends on what you mean by intrinsic. It's all linear algebra.
The generic spin state for the electron is $$ |\psi\rangle= \cos\theta|\uparrow\rangle +e^{i\phi}\sin\theta |\downarrow\rangle $$ and acting on it by the three 2$\times$2 matrix operators $\vec s$ yields $$ s_z|\psi\rangle = {\hbar\over 2} (\cos\theta|\uparrow\rangle -e^{i\phi}\sin\theta |\downarrow\rangle),\\ s_x|\psi\rangle = {\hbar\over 2} (\cos\theta|\downarrow\rangle +e^{i\phi}\sin\theta |\uparrow\rangle),\\ s_y|\psi\rangle = {i\hbar\over 2} (\cos\theta|\downarrow\rangle -e^{i\phi}\sin\theta |\uparrow\rangle),\\ \vec s\cdot \vec s |\psi\rangle = {\hbar^2} {1\over 2}\left ( {1\over 2}+1\right )|\psi\rangle. $$
So, e.g., starting from the state with θ=0, you get eigenvalues for $s_z$ and $\vec s\cdot \vec s$, but rotated states for the other two operators, $s_x$ and $s_y$. See WP.
For your title question, start from θ=π/2.
Cosmas Zachos
  • 67,623
