For the complex Klein-Gordon Lagrangian density in the non-relativistic limit, we can decompose the complex scalar field into the form $$\phi=\frac{1}{\sqrt{2m}}e^{-imt}\psi.$$ When substituting the explicit form of $\phi$ into the lagrangian density, you end up with this term:
$$L=\frac{i}{2}\psi^*\dot{\psi}- \frac{i}{2}\dot{\psi^*}\psi +\frac{1}{2m}\dot{\psi^*}\dot{\psi} -\frac{1}{2m}\partial_i\psi^*\partial^i\psi -\frac{i}{2}\psi^*\partial^i\psi -\frac{1}{2m}\dot{\psi^*}\partial^i\psi +\frac{1}{2}\partial_i\psi^*\psi -\frac{1}{2m}\partial_i\psi^*\dot{\psi}.$$
The dot means the time derivative. In the solutions, this was simplified so that only the last four terms remained. What I do not understand is how exactly the first four terms were cancelled out? Any tips on how to do this would be greatly appreciated! I understand this question has probably been asked before, but this exact specific issue is really confusing me.
