Here is a question I have always wondered about.
- I have a family member that dislikes drinking hot beverages (e.g. coffee, tea). https://www.flickr.com/photos/adamcohn/16290609394
- This family member after preparing the drink will stretch their hand as high up as they can .... and pour it from a large height into another contained, and a lot of steam will come out of the drink.
- Then, they will pour it back into the original cup and repeat this process again and again.
- After doing this several times, the temperature of the drink will have significantly cooled.
My Question: I am wondering if there are some mathematical equations that can describe the relationship between heat transfer and the height at which the coffee is poured from. For example, if I poured a hot cup of coffee from a height of 10 meters - given the temperature of the surroundings, what would the "average" temperature of the coffee be by the time it finished travelling 10 meters?
In more mathematical terms:
Given:
- A 250 mL cup of coffee initially at 80 degrees Celsius.
- An ambient room temperature of 23 degrees Celsius.
- The coffee is poured from a certain height of $Z$ meters.
I found the following 3 equations which might be helpful
- Newton's Law of Cooling:
$$\frac{dT}{dt} = -k(T - T_{\text{env}}),$$
where:
- $T$ is the temperature of the coffee,
- $T_{\text{env}}$ is the ambient temperature,
- $k$ is a heat constant
- Bernoulli Principle
$$P + \frac{1}{2}\rho v^2 + \rho gh = \text{constant},$$
where:
- $P$ is the pressure of the fluid (coffee),
- $\rho$ is the density of the fluid,
- $v$ is the velocity of the fluid,
- $g$ is the acceleration due to gravity,
- $h$ is the height from which the coffee is poured.
- Fluids in Free Fall: Question about fluid in free fall flow
But I am not sure this coffee situation can be simplified (e.g. model it based on Brownian Motions) and these mathematical principles be applied to this situation to understand the relationship between the height at which coffee of a certain temperature is poured and the rate of heat transfer.
Does anyone know if this is possible?
