Some time ago i saw this question Why does water falling slowly from a tap bend inwards?
Which explains why the water flowing from a tap bend inwards while falling, using an inviscid flow model. However all calculations there assume steady flow, so that the continuity equation and bernoulli can be used in the usual forms.
But i don't see how can a free fall flow ever can be steady. I know it is the case, but i struggle to understand how a free fall flow would transition from unsteady to steady.
I imagine, for instance, a large volume of water with the exit closed at the bottom. At a initial moment, the bottom exit opens, and the water starts moving from rest. Since the fluid is now unconstrained, the pressure reduces to zero (or simply atmospheric pressure) and the water falls due to gravity, but every single point of the water should fall with the same acceleration g, therefore there is no relative motion between the fluid parts, so it should fall as an unique body. The flow is unsteady of course and would simply be that $\frac{\partial v}{\partial t} = g$.
How would this flow ever become steady?
