I've just done a double-slit experiment in our school club using a simple kit with a pair of razor blades and a laser pointer. We put the razor blades together, cut a double slit in a clear film, and shot the laser pointer through the slits. The experiment worked out fine. Just as we expected, the laser pointer, which projected a single dot before, showed a line of small dots, obviously the result of the wave-particle duality. and we tested it on the uncut clear film, just to make sure the pattern wasn't a result of light scatter.
However, just for fun, we cut a single slit in another clear film, and shot the laser pointer again. Strangly, even though it wasn't a double slit, a double slit pattern still appeared.
Any ideas on how this can be explained?
