It's been a long time since I did problems on friction but here's one...
Consider a cuboidal block of dimensions 123 meters with a total mass of 1 kg. There are 3 cases that we need to look at:
- Its base of area 1*2 sq. meters is in contact with the surface
- Its base of area 1*3 sq. meters is in contact with the surface
- Its base of area 2*3 sq. meters is in contact with the surface
for all the above cases, the coefficient of friction ($\mu$) is a constant. the normal force ($N$) is also the same since the weight of the block is the same and $N$ has to equal the downward acting force mg
since $f = \mu N$, that means the friction force is the same in each of the three cases.
That means the friction force is independent of the orientation of the block!? But that doesn't make sense... with a larger contact area friction should intuitively increase. If friction doesn't, what does? And does the contact area even matter then?
