My post is an elaboration of those here and here.
In my AP Physics C class, I was introduced to the following equation for center of mass (CM): $$x_\text{cm} = \frac 1M \int x\, dm.$$ Above, $dm$ represents a "slice" of the given object.
Problems would then be solved using the below format:
Prompt: "Find the CM of a metal rod with constant density, mass $M$, and length $L$."
Observe that $M/L = dm/dx$ so $dm = \frac{M}{L}\, dx$. Then: $$\begin{align*}x_\text{cm} &= \frac 1M \int x \, dm \\ &= \frac 1M \int \frac ML x\, dx \\ &= \int^L_0 \frac{x}{L} \tag 1 \\ &= \frac{L}{2}\end{align*}$$ The boundaries of integrations at (1) appear since the object ranges from $x = 0$ and $x = L$. They are not specified in the formula though because we don't necessarily integrate over $x$. For more examples of this form of problem-solving, see Dan Fullterton's video.
I am confused by the statement:
"Observe that $M/L = dm/dx$ so $dm = \frac{M}{L}\, dx$."
Manipulation of $dx$ and $dm$ is mathematically undefined since infinitesimals aren't variables.
Since I couldn't understand the class-provided technique, I ended up employing the equation below for an object spanning $x = a$ to $x = b$: $$x_\text{cm} = \frac 1M \int^a_b \lambda(x) x\, dx.$$ Above, $\lambda(x) = \rho (x) \cdot A(x)$ where $\rho(x)$ provides the average density at the object's intersection with the plane at $x$, and $A(x)$ is the area of that intersection.
Is this a valid alternative equation? Also, how does the earlier technique work in a technical sense?
Bucheye
Your alternative equation is valid.
A more technical way of understanding the mathematically undefined equation is by multiplying both sides by $x$ and then integrating both sides with respect to $dx$:
$$\frac{M}{L} = \frac{dm}{dx},$$
$$\int{x\frac{M}{L}} dx = \int{x\frac{dm}{dx}} dx.$$
Now, we can substitute $dx = \frac{dx}{dm} dm$ on the right side:
$$\int{x\frac{M}{L}} dx = \int{x \frac{dm}{dx} \frac{dx}{dm} dm}.$$
And then we simplify $\frac{dm}{dx} \frac{dx}{dm} = 1$, and we're left with the desired expression:
$$\int{x\frac{M}{L}} dx = \int{x dm}.$$
Travis
  • 3,562
the mass is equal to the density time volume
$$M=\rho\,V$$ thus if the density $~\rho~$ is constant then $$dM=\rho\,dV=\rho\,A\,dx$$
where the area $~A~$ is constant
$\Rightarrow$
$$\frac{dM}{M}=\frac{\rho\,A\,dx}{\rho\,V}=\frac{\rho\,A\,dx}{\rho\,A\,L}= \frac{dx}{L}$$
Eli
  • 13,829
Observe that $M/L=\mathrm{d}m/\mathrm{d}x$ so $\mathrm{d}m=\frac{M}{L}\mathrm{d}x$
This really isn't the best way to state this. A more clear way is that for a uniformly dense rod, the linear (mass) density is $\lambda=M/L$. But since the mass density is constant, we can also say that for an infinitesimal slice of the rod, the mass of the slice is $\mathrm{d}m$ and must be equal to the product of the density and the (infinitesimal) length, $\mathrm{d}x$:1 $$\mathrm{d}m=\lambda\,\mathrm{d}x$$
You can then substitute this into your COM equation, $$\frac{1}{M}\int_{0}^{M} x\,\mathrm{d}m=\frac{1}{M}\int_{0}^{L} x\lambda\,\mathrm{d}x=\frac{1}{M}\int_{0}^{L} x\frac{M}{L}\,\mathrm{d}x=\frac{1}{L}\int_{0}^{L} x\,\mathrm{d}x=\frac{L}{2}$$ Note that in the first equality, when we made the change of variables, we had to change the limits of the integrals--it was easy in this case, but in some other changes of variables yield more difficult limit changes.
This method is essentially equivalent to the alternative method you've discovered yourself.
1. Note this would also be equivalent to saying that the mass density is the derivative of the mass with respect to the position: $\lambda=\mathrm{d}m/\mathrm{d}x$.
Kyle Kanos
  • 29,127
-1
For your uniform density rod of constant cross-section,
and the relationship follows.
If you do not like the way that $dm/dx$ was used as a fraction then go back one step and use the fraction $\delta m/\delta x$, do the algebra, and then take a limit $\delta x\to 0$ for the summation which is where the integral comes from.
Your use of $\lambda(x) = \rho (x) \cdot A(x)$ is fine and note that $\lambda(x) \cdot dx= \underbrace{\rho (x)\,A(x)\,dx}_{dm}$.
Farcher
  • 104,498
