Suppose light from a laser passes through a single vertical slit. The width of the slit is certainly a factor how the light scatters after it goes through the slit; the thinner the slit, the wider the scattering.
But my question is about the material surrounding the slit. How does the depth of the material influence the scattering pattern? And how does the composition of the material itself influence the scattering pattern?
Does the nature of material around the slit significantly affect the scattering pattern?
Craig Feinstein
  • 1,010
  • 24
There are a number of ways of looking at this problem. Some are not very intuitive and don't really seem to match reality. But they give the right answer.
One early explanation that give the wrong answer is ray optics. It works for many things, but does not explain diffraction.
It says that light propagates in a straight line. This predicts a geometric shadow of the slit. So we need a better approximation of what is really happening.
Light is a wave. If you toss a rock in a pond, you see a wave spreading out in all directions.
If you toss many rocks in a line, each rock generates its own circle. The waves from each circle add. Some reinforce and some cancel. The result is the same as if you tossed a stick in the water. A straight wave spreads out from the stick.
You can do the same thing with light. A point source of light leads to an expanding spherical wave. A plane source of light is equivalent to many point sources. It leads to a plane wave.
You can take this idea further. A plane wave propagates in a straight line. Suppose such a wave propagates up to plane A and continues on to plane B. You get the same wave B if you have a set of point sources at A. It is as if the plane wave is a set of point sources of expanding spherical waves that continually generates new point sources as it propagates.
Now add in a slit at A. When the wave hits, only the point sources inside the slit are left. And what you get at B is exactly what this view predicts. So whether or not this idea matches reality, you have experimental evidence in favor of it. This was the earliest explanation of diffraction. It can still be used today. This tells us that diffraction is a consequence of the wave nature of light.
In this view, the shape of the slit is important. The material is not. The role of the material is to absorb the light that hits it and extinguish the point source that would have appeared.
Another way of looking at it is that light is an electromagnetic wave. Maxwell's equations describe the propagation of such a wave. You specify boundary conditions appropriate to a particular problem, and calculate the state of the wave in the future.
These equations predict that oscillating charges generate waves, and waves keep going after they are generated.
If the initial condition is a point charge oscillating up and down, you get expanding spherical waves with a particular polarization and intensity pattern. A small sphere of charges vibrating randomly generates a uniform spherical wave. A plane of charges generates a plane wave.
The material around a slit is a boundary condition. A wave propagates up to a slit, and all but the wave inside is absorbed. Maxwell's equations predict the future of the rectangular patch of wave that passes through. It matches what we see.
In this view, the material is charges that interact with the wave. One instructive example is if the material is a smooth metal. Metals contain freely moving electrons. The surface of the metal can be approximated as a sheet of freely moving charges. Such charges are accelerated by the incident wave. This absorbs the energy of the wave. However, accelerating charges generate a new wave. This adds up to a mirror reflection.
If the metal is very thin (say less than a nanometer), absorption is incomplete. The intensity of light decays exponentially in a sheet of charge. For a thin sheet, some may exit the other side. So we get some explanation of why the material absorbs.
We have lots of experimental support for light as an electromagnetic wave. This is in widespread use today. It was considered to be the ultimate answer until about 1900, when several things turned up that it could not explain. These include the photoelectric effect. The energy in very dim light seems to be concentrated in lumps. Electrons orbiting a nucleus is accelerated and should radiate away its energy. It should spiral into the nucleus in a small fraction of a second.
Quantum mechanics is the next explanation. Light consists of photons. Photons are like nothing classical. Their behavior is counterintuitive. The ideas are strange and hard to get used to. In an effort to make them understandable, photons are described as both a classical wave and a classical particle. This is close enough to the truth the make you think you understand, and far enough that you get confused if you reason from it. Here are a couple posts where I try to explain a bit more realistically. But the thing that predicts the actual behavior is the math.
How can a red light photon be different from a blue light photon?
Does the collapse of the wave function happen immediately everywhere?
A photon is described by a wave equation. The Schrodinger equation predicts how the photon propagates. The wave predicts the probability of where the photon can be found and the momentum of the photon. Like Maxwell's equations, a slit is a boundary condition that affects how the wave propagates from there on. The Schrodinger equation predicts the future state of the wave. This leads to a prediction of where the photon probably will be found.
The uncertainty principle provides a bit of explanation. Constricting the region where the wave is reduces the uncertainty in side to side position of the photon. This necessarily increases the uncertainty in side to side momentum. This means the photon can be found farther sideways than ray optics would predict.
Quantum mechanics has experimental support even in cases where Maxwell's equations fail. It explains chemistry. Electrons in an atom have orbitals. The absorb and emit when they change orbitals. More complex orbitals are found in molecules. In metals, electrons are not restricted to individual atoms. The energy structure forms bands.
In this view, the material has charges that can emit and absorb photons. The thickness of the material matters as in Maxwell's equations. The type of material matters because different electron configurations absorb differently.
Given material covered in black paint, there is a quantum mechanical explanation of why this material absorbs so well. But for chemists, the usual way is to understand the properties of the chemicals and not dig into quantum mechanics unless necessary.
mmesser314
  • 49,702
In general, no. Scattering implies a random nature (which can occur for particles thru a slit), diffraction is the correct term you are looking for. Diffraction is due mainly to the medium material and the wave nature of energy transmission in that medium, not the slit material, the medium being water, air of the EM field for example.
Note that for single slit wave diffraction for water, air we get ring like patterns .... but for light we get an additional single slit property called "interference".
PhysicsDave
  • 2,886
The material around the slit does not have much, but some, influence if it is thick enough and/or absorptive enough so that no light passes. It may have some influence because light can still enter it to a certain depth. The thickness also has influence. The result is that the diffraction orders do not quite have the same intensity and phase as in the Fourier transform, that is the thought experiment of a perfectly absorbent, infinitely thin screen material. A property of significant influence is the polarization of the light because the boundary condition for the field inside the slit may depend strongly on it. Also look up attenuated phase shift masks.
my2cts
  • 27,443
The expected and educated answer is diffraction for single-slit and interference for double-slit.
But, both math models of diffraction and interference are the same because the slits are continuous regardless all things are discrete and have a finite number of atoms. So, the varieties of atoms that slits are made become the indistinguishable geometrical continuum of uncountable math point, and their electromagnetic fields vanish.
Richard Feynman considered diffraction and interference to be indistinguishable. I think he is right. Of course, the quantum people disagree. After all, we have the right to make a living.
I believe the right physics answers should have their real-world correspondences and be discrete because our nature is discrete and finite. In real-life practices, such as engineering and science, two answers or measurements are the same when they differ by the magnitude of the scale of an atom, say hydrogen, to be safe. So, discrete or quantum is the reality, and continuous is the math computation technique, including first and second derivatives. Moreover, most numbers, including the square root of 2, have no real-world correspondences.
