I am building a tool which extracts the elemental composition of a light source using its emission spectrum. Therefor, I'm currently writing down the emission spectra of individual elements, but I'm not sure which wavelengths to include and which I should discard. I'm using the NIST database as a reference for the spectra. For example, let's look at the hydrogen spectrum (strong lines in air).
Firstly, there is the question of how to define the span of visible wavelength. I'm seeing a lot of different opinions and have concluded for myself that 385 nm to 750 nm is an acceptable range. But that would mean that I have to use the following wavelengths:
[388.90, 397.01, 410.17, 434.05, 486.13, 656.27] nm
But most of the time I'm seeing the lines at 388.90 nm and 397.01 nm disregarded.
The whole thing gets more complicated when looking at helium where the data differs hugely from the spectral lines I've seen over the internet:
[388.8, 410.2, 434.1, 447.1, 471.3, 486.1, 492.1, 501.5, 504.7, 587.5, 656.3, 667.8, 686.7, 706.5, 728.1]
So basically I'm asking for opinions on which wavelengths I should use and which I shouldn't use. Is the range for which I defined visible light acceptable. Should I discard wavelengths which don't satisfy a certain threshold for their intensity?
oodani
  • 13
