I have been trying to figure out the solution to this problem of finding the "velocity" of de-Broglie's wave. I have tried to see answers from countless sources but none of them helped. My book provides me with the solution that : v = (hf)/(mc) . Where m is the mass of particle , f is the frequency, h is Planck constant and c is speed of light.
And this came from the fact that they used the formula c = f×(lambda) and substituted it in de-Broglie's equation for wavelength of a particle (= h/p) , which is really absurd to me as to why does the speed of light come here? Shouldn't it be v(wave)= f×(lambda) . Now I've also read that it has something to do with group velocity of matter waves but none of the sources which I read really explained as to why speed of light should be at play here. Can anyone explain this?
The important notion here is known as the dispersion relation of the wave. It relates the temporal properties of the wave (i.e., its frequency $\omega$) to the spatial properties of the wave (i.e., its wave vector), and this relationship is different for different types of wave. For light in vacuum, the relationship is exactly $\omega=ck$ so that $\omega$ grows linearly with $k$, but for matter waves, the relationship is different. The dispersion relation is computed using the corresponding "wave" equation which represents the equation of motion for the system: it comes from Maxwell's equation in the context of light and from Schrodinger's equation in the context of quantum particles.
Details below the break.
For completeness (and we will use these below):
de Broglie's hypothesis relates the energy of a matter wave to its frequency, i.e., $E=hf = \hbar\omega$, and the momentum to its wavelength, i.e., $p = h/\lambda = \hbar k$.
Now, the energy of a free particle of mass $m$ is given by just the kinetic energy, $p^2/2m$. According to the de Broglie hypothesis, the momentum of a particle is given by $p=\hbar k = h/\lambda$, i.e, the momentum of a particle is related to the spatial characteristics of the corresponding matter wave. Then, using the kinetic energy of a particle, we can derive the dispersion relation for matter waves as $$ \hbar\omega = E = \frac{p^2}{2m} = \frac{(\hbar k)^2}{2m}\,, $$ so that $$ \omega = \frac{\hbar k^2}{2m}\,. $$
Now, without getting into the details (you should look these up), the phase velocity of a monochromatic wave of angular frequency $\omega$ is given by $v_p=\omega/k$, whereas the group velocity of a wave-packet centered near $k$ is give by $v_g = d\omega/dk$. Therefore, for a matter wave, $$ v_p = \frac{\omega}{k} = \frac{\hbar k^2/2m}{k} = \frac{\hbar k}{2m} =\frac{h}{2m\lambda}\,, $$ and $$ v_g = \frac{d\omega}{dk} = \frac{d}{dk}\frac{\hbar k^2}{2m} = \frac{\hbar k}{m} =\frac{h}{m\lambda}\,. $$
We can see that $c$ never appears here. In the context of light waves, since the dispersion relation is $\omega = c k$, then we can compute the phase and group velocities as $$ v_{p,\textrm{light}} = \frac{\omega}{k} = \frac{c k}{k} = c\,, $$ and $$ v_{g,\textrm{light}} = \frac{d\omega}{dk} = \frac{d}{dk}(c k) = c\,, $$ and so in that context, the phase and group velocities for light is equal to the constant $c$, as it should.
march
  • 9,501
