My question is the following: I have two pots. Pot A and pot B. I fill both of them with 1l (litre) of water. Now I add a table spoon of salt into pot A. Which water is going to start boiling first?
I was researching this question and came across two posts on this website:
Does salt affect the boiling time of water?
The first one states the following:
Adding salt increases the boiling point, so you need to get the salt solution hotter to make it boil. However for saturated salt solution the specific heat falls by about 22% while the boiling point only goes up by 8%, so the salt solution still boils faster even taking into account the elevated boiling point. However for saturated salt solution the specific heat falls by about 22% while the boiling point only goes up by 8%, so the salt solution still boils faster even taking into account the elevated boiling point.
The second one states the following:
It depends on how much salt you add.
So is it now dependent on the amount of salt or not?
After looking on google you can find answers on quora for example that say adding salt decreases the time until the water starts boiling and also answers that state the opposite.
What is now the case? Is it even possible to give a simple answer?
On quora I found an answer stating the following thing:
BUT, if you have the same amount of water in two pots and you add salt to one and not the other, the one without the salt will boil quicker.
What am I missing?
