As far as I have read so far, proper time is the time measured on the clock of an inertial frame moving uniformly with respect to another inertial frame. The concept and the mathematical expression for proper time is originated from the concepts of relativity of simultaneity and time dilation, both of which are evident from the fact that the quantity "interval" between two events remains constant in all the inertial frames. The conclusion is that the quantity proper time has a meaning only when we are talking about an inertial frame of reference.
I encountered a question in my exam: $$ x(t) = \sqrt{(b^2)+((ct)^2)} $$ The equation of motion of a particle in the ground frame of reference is given by the above equation. Calculate the expression for proper time. (This question is taken by Griffiths, Electrodynamics book).
I have two doubts about this question:
Does it make sense to define proper time for an accelerating object?
Assuming that the answer for Q1 is yes, then is it calculated by transforming coordinates into a new reference frame moving with velocity v for every small time dt? i.e., for every small change in dt there is a change in velocity of the particle as seen from ground frame. So, do I have to change my frame for every dt time, and sum up the dT? dT - infinitesimal proper time.
