"In the gas phase, the molecules are freely moving particles traveling through space, where the kinetic energy associated with each particle is greater than the potential energy of intermolecular forces."
Qualitatively, this makes perfect sense. The particles have are moving very quickly which trumps any attractive forces.
However, I don't quite understand the energetics of such a situation. This motion is where the kinetic energy term comes from. On the other hand, the tendency for the particles to attract is represented by a potential energy term. Two particles that are attracted to one another in close proximity would have a positive potential energy, right? How do we know that the kinetic energy term has to be greater than the potential energy term?
EDIT IN RESPONSE TO ANSWER
Thought I would post this in case anyone else was confused. This is my rationalization of the answer.
This has cleared up a lot for me. This also has to be why solids vibrate in place. For the following, assume two particles in one dimension. Assume the particles are at some finite distance from each other, each with no KE. Call this distance d. We can define the PE to be 0 at this distance, d. Since they attract each other, they fall towards one another. The attractive force is applied across the distance between them, hence work. The amount of work (or force * dist) to bring the particle to a certain velocity is its kinetic energy. In other words, all of the PE is converted to KE. Assuming the particles then “collide,” elastically of course, the particles reverse directions. They are now moving away, each with some KE. They still attract one another, however. The attractive force will apply itself across some distance. Well the amount of work to stop them will be equal to their KEs. This will happen at a distance at the distance d. At this point, there will not be enough KE to keep moving away from one another. They fall back towards one another and the process repeats. This is the vibration. In a gas, there is not enough attraction to stop the moving away from one another. In other words, the KE outweighs the PE.
