I've been told that in QFT, everything is turned into their continuum type, i.e:
$$q_i \to \phi(x)$$ $$p_i \to \pi(x)$$ $$[q_i, p_j] = i\delta_{ij} \to [\phi(x), \pi(y)] = i\delta(x-y)$$
etc.
Now I've been wondering how one would represent states in this theory. Knowing that in QM, a state of n-variables can be represented as:
$$|\Psi\rangle = \int dq_1\dots dq_n \psi(q_1,\dots, q_n) |q_1, \dots, q_n\rangle$$
I suspect in QFT, a state would be represented something like:
$$|\Psi\rangle = \int \mathcal{D}[\phi] \psi(\phi)|\phi\rangle$$
Is that the case? Moreover, in some sense, is every concept in QM updated to fit into QFT? i.e.:
$$i\frac{\partial}{\partial t} \psi(\phi, t) = \mathcal{H}\psi(\phi,t)$$
If so, how would then generalize the momentum operator? $$-i\frac{\partial}{\partial q_i} \to \frac{\delta}{\delta\phi(x)}$$
Cosmas Zachos
  • 67,623
Habouz
  • 1,376
Yes, the states in quantum field theory are what are called "wave functionals." The momentum operator is represented by a functional derivative, $\pi(\mathbf{x}) \rightarrow -i\frac{\delta}{\delta \phi(\mathbf{x})}$. Note that the minus sign comes from the fact that, in 1-d a right-going wave has the form $\psi_p(x) = e^{ipx/\hbar}$. To get $p\psi_p(x)$ you need $-i\hbar \frac{\partial}{\partial x}$.
Sean E. Lake
  • 22,927
