-3
How is quantum entanglement different from a controlled experiment where a pineapple is smashed at a high speed to a perfectly symmetric object and measuring one of its piece in air for spin, speed, direction etc. and finding correlations with other pieces of pinapple in mid air?
In quantum mechanics information cannot travel from piece A to piece B at faster than light to explain the correlation so the result is seen as unexpected (at least to people outside the science community like me) and at any time a piece can have any property but once the properties of a piece is measured the wave function will collapse and the properties of other piece or pieces becomes clear.
But isn't the correlation simply due to how the piece or particle was generated? No information needs to travel because the particle is simply continuing to react to the same common generation event? If we can call it information isn't it already with all the particles or pieces of pineapples in air already?
I (am a beginner, used to be interested in physics but nobody gave me answers so lost interest eventually and took a career in finance. this one was one of my questions) also view quantum mechanics as deterministic rather than probablistic but think the probablistic approach is necessary because we cannot measure all the variables with our very limited measuring and processing capabilities. For example, a roll of die by a machine is deterministic if we measure and process everything from the light fluctuation in power, air movement in real time, mass of the die, initial position, curvature, area of contact, etc. but because that is too complicated we use it as random with a probability. I feel in quantum physics we are doing the same thing as it is simply more practical, but everybody I talk to truly believe I am wrong. Mentioning this as it is related to the question, that is, the properties can be calculated without measuring in quantum mechanics if we have virtually unfathomable knowledge, measurement capability and processing power. We don't have that so in my view too probablistic quantum mechanicsm is the way science can progress, so no question about that, but is it established that quantum mechanics cannot be deterministric in reality?
Just want to know where and why I'm wrong. Thank you in advance.
Chandan
There is a classical joint probability distribution for the outcomes of the various measurements you can make on the pieces of your pineapple. Therefore those measurements satisfy Bell's theorem. Therefore this is not a useful analogy to quantum mechanical systems where Bell's theorem is violated and no joint probability distribution exists.
WillO
  • 18,387
A simpler example would be is to have 2 envelopes, put a slip of paper with +1 into one envelope and a slip of paper of -1 into the other envelope. Seal the envelopes and mix them up. Send one to a friend in Japan and another to a friend in the US. Of course you've told them already that there are 2 envelopes, one with +1 and the other with -1, but you don't know which person will receive which envelope. Your friend in Japan opens their envelope and finds "+1" and knows instantly that the other person has the enveloped with "-1."
Is this entanglement ? They're correlated, and you've updated your state of knowledge. But this isn't the sort of entanglement that's of use in quantum mechanics for computation or other weirdness. The description using simple games is bit more complicated than the above.
