Is it possible to measure the effects of $SU(2)$ rotations acting on spinor wave functions $\psi$ in the fundamental representation? That means, is it possible to extract information that distinguishes $SU(2)$ from $SO(3)$ rotations?
These are basically two questions:
- How would an observable, a matrix element … look like mathematically?
- What would be an appropriate experimental setup?
In principle the effects of the $SU(2)$ rotations can be calculated quite easily, but it is not clear to me how they can be measured. The following is just a collection of ideas.
Regarding (1) a first idea – but there may be others – goes into the direction of the Aharonov-Bohm effect, but including a non-vanishing, constant magnetic field. The reason is that an $SU(2)$ rotation
$$ U_\alpha = e^{-i \sigma_k\alpha_k /2} $$
has the same structure as one of the interaction terms
$$ H_\text{int} \sim \sigma_k B_k $$
for a spinor coupled to a constant magnetic field $B$ in the Pauli-equation, when promoted to the time evolution operator
$$ U(t) = e^{-iHt} = e^{-iH_At} \otimes e^{-i \sigma_k\alpha_k /2} $$
where the first exponential depending on the vector potential $A$ acts on position space only, the second one depending on the magnetic field $B$ acts on spin space only, and where I used $\alpha_k \sim B_k \, t$.
If we are able to let an appropriate interaction rotate the spin in just one one of two components of a spinor wave function
$$ \psi_0 = \psi_{0,1} + \psi_{0,2} $$
$$ \psi(t) = U_{B=0}(t) \, \psi_{0,1} + U_{B \neq 0}(t) \, \psi_{0,2} $$
and to measure the interference pattern of $|\psi(t)|^2$ that may demonstrate the effect created by the $SU(2)$ rotation.
Splitting the wave functions into position and spin part
$$ \psi_\chi(r) = u(r) \otimes \chi $$
and using $B$ in y-direction we get
$$ |\psi|^2 = |u_1|^2 + |u_2|^2 + (u_1^\ast u_2 + u_2^\ast u_1 ) \, \cos(\alpha /2) $$
where the cosine is caused by the $SU(2)$ rotation, $\alpha \sim B \, t$.
As said, this is just an idea, there may be others to address question (1).
Regarding an experiment (2) to measure the effects derived from the idea (1) I see several problems: The idea looks feasible only in the case of a constant magnetic field $B = \text{const}$. The effect of the magnetic field $B$ rotating the spin part $\chi$ is mixed with the interaction caused by the vector potential $A$ acting on the position space wave function $u$; therefore, it is not clear how to extract the sole effect of the $SU(2)$ rotation. The ansatz with the interference of two components requires us to confine $B$ to a spatial region, such that only one component is affected by the rotation, whereas the other component does not feel any interaction with $B$ (but still with $A$).
