I'm considering the Ising model in a field on a square lattice in $d$ dimensions: $$H = -\sum_{\langle i j \rangle} \sigma_i \sigma_j - h \sum_{i} \sigma_i$$ As usual, $\langle i j\rangle$ refers to nearest neighbor couplings.
When $h>0$ and $0< T < \infty$, it follows that there is a finite magnetization density of $\mathbb{E}[\sigma_i] = m(h, T)>0$ in the thermodynamic limit.
One can imagine this might occur because there are more or larger finite domains of up spins than down spins, and that either of the following situations could arise:
  1. The up spins percolate in the system, so that there is a nonzero probability that a given spin is part of an infinite domain of up spins.
  2. The up spins do not percolate in the system, so that there is no infinite cluster of up spins containing a finite density of spins, but the fact that there are more or larger finite domains of up spins than down spins is sufficient to give a nonzero magnetization.
In the $1$d model, the latter mechanism without an infinite cluster occurs. In the $2$d model, I believe that the former mechanism with an infinite cluster occurs, at least for low temperatures. However, it's not clear to me that this holds at high enough temperatures. I go a little bit back and forth - I'm tempted that high temperatures (say large relative to $T_c$) should have only finite domains of either size, but I feel this would necessitate a phase transition on changing $T$ at nonzero $h$ which should not occur.
In $d > 1$, $h>0$, do the up spins percolate at all $0<T<\infty$? I believe they do at low temperature, but am less sure about high temperature (high relative to $T_c$).
user196574
  • 2,482
Of course, when $h$ is large enough, the $+$ spins will percolate and not the $-$ spins (for instance, one can show that the $+$ spins dominate a very high density Bernoulli site percolation). Therefore, I'll mostly discuss what should happen when $h>0$ is small.
Subcritical temperatures ($\beta>\beta_c$)
In any dimension $d\geq 2$, it is known (see this paper) that the $+$ spins percolate when $h=0$. By monotonicity, this still holds for any $h>0$.
Moderately subcritical temperatures and small $h>0$
  • In any $d\geq 3$, as long as $h>0$ is small enough, there should exist $\tilde\beta>\beta_c$ such that both the $+$ and the $-$ spins should percolate when $\beta\in (\beta_c,\tilde\beta)$. As far as I know, this has only been shown rigorously when $h=0$ and $d\gg 3$, see this paper. However, this should still happen when $h>0$ is sufficiently small, since this would only very slightly change the density of $+$ and $-$ spins.
  • The case $d=2$ is very different, as there can never be coexistence of infinite $+$ and $-$ clusters, see again this paper. In particular, $+$ spins percolate in this case and not $-$ spins.
Very high temperatures ($\beta\ll 1$) and $h>0$ small enough
In this case, the spins are nearly independent, so that the Ising model is a small perturbation of Bernoulli site percolation with parameter very slightly larger than $1/2$ (since $h>0$ is taken very small).
  • When $d=2$, the percolation threshold is approximately $0.59$, so that there should not be percolation of $+$ spins (neither $-$ spins of course).
  • When $d\geq 3$, the percolation threshold is much lower than $1/2$, so that there should be percolation of both $+$ and $-$ spins.
I don't know a reference, but this does not seem very hard to prove (but I may be wrong, of course).
There is another, substantially more relevant, type of percolation that has been investigated: the percolation of Fortuin-Kasteleyn clusters (keywords: random cluster model, FK-percolation; this is the representation on which the Swendsen-Wang algorithm is based). For this notion of percolation, the onset of percolation exactly coincides with the usual phase transition in the Ising model when $h=0$, in any dimension. When $h\neq 0$, there is a nontrivial curve in the $\beta/h$ plane separating the percolative and non-percolative regimes, even though there is no phase transition in this regime (all thermodynamics quantities and all correlation functions are analytic, by the Lee-Yang theorem and related works). This curve is know as the Kertész line. There are quite a few works on that (both rigorous and numerical). You should not have too much trouble finding them using this terminology.
Yvan Velenik
  • 11,352
