According to quantum mechanics, for multi-electron atoms, a single electron around the nuclei can be in the state of linear combination of different eigen energy states. In that case, even the energy of the electron is not one of the eigen energies.
In chemistry, we often say that an electron is in an orbital (such as 1s, 2s), another electron is in another orbital, etc. How does it make sense if an electron is in a linear combination state?
NGY
  • 601
While it's possible for the atom to be in a superposition on energy states, the superposition collapses to an eigenstate as soon as we observe it. Therefore every atom we observe will have a distinct electronic configuration.
Incidentally, note that for a multi electron atom the assignment of electrons to the atomic orbitals 1s, 2s, etc, is an approximation. The electron correlation mixes up the atomic orbitals so strictly speaking we don't have separate atomic orbitals, just a single wavefunction for the atom. However, in most cases using atomic orbitals is an excellent approximation.
John Rennie
  • 367,598
As John Rennie points out, the picture of an electron in an orbital breaks down in multielectron atoms because of electron correlations. However, you can still assign a "fraction" of an electron to an orbital by diagonalizing the reduced one-particle density matrix (1RDM) of the system. This matrix is Hermitian, positive semi-definite, has eigenvalues $n_i \leq 1$, and describes the total electronic density of the system as \begin{equation} \rho (r) = \sum \limits_i n_i \psi_i^*(r) \psi_i(r) \end{equation} where $\psi_i (r)$ are the orbitals. Thus, $n_i$ is the "occupation number" of orbital $\psi_i$ and describes how much on average an electron is in that orbital.
Now, with respect to your question: "In chemistry, we often say that an electron is in an orbital (such as 1s, 2s), another electron is in another orbital, etc. How does it make sense if an electron is in a linear combination state?" Well, it makes sense because often we find that there are $N_e$ (number of electrons) eigenvalues $n_i$ which are very close to one, while the rest of the eigenvalues are very small. The reason for this is that the exact wavefunction is an infinite sum of Slater determinants (i.e., an antisymetric function which describes one electron configuration) considering all possible configurations. However, because of the variational principle, configurations which are very high in energy contribute very little to the wavefunction and hence have small weights $n_i$.
There are cases in which the eigenvalues of the 1RDM differ significantly from one or zero. This occurs if there are different possible configurations that are similar in energy. For example, in transition metals, configurations involving 4s or 3d orbitals are very close in energy. This is the reason for which the configurations predicted by the aufbau principle break down for these elements.
Goku
  • 563
