Suppose we want to calculate the expectation value $$\langle x|[\hat{x},\hat{p}]|x\rangle,$$ where $|x\rangle$ is an position eigenstate, so that $\hat{x}|x\rangle=x|x\rangle$ and $\langle x|\hat{x} = x\langle x|.$ If we 'forget' for a moment the canonical commutation relation, we get $$\langle x|\hat{x}\hat{p}|x\rangle-\langle x|\hat{p}\hat{x}|x\rangle = x\langle x|\hat{p}|x\rangle- x\langle x|\hat{p}|x\rangle = 0,$$ which, according to the generalized uncertainty principle $$\Delta x\Delta p \geq\left|\frac {\langle-i[\hat{x},\hat{p}]\rangle} {2}\right|,$$ means that when we are on a position (or momentum) eigenvector we can measure simultaneously (as accurately as we want) position and momentum (!?).
What's wrong with my reasoning?
Buzz
  • 17,816
Loukas
  • 57
Your teacher has presumably taught you the way out of all these pseudoparadoxes: Consider Gaussian states of vanishing width. Instead of doing that, effectively hijacking your question to something more interesting, I will remind you of the erroneous way you are multiplying 0 to infinities of different orders!
The short answer is that, technically (physics aside: there is little physics in $|x\rangle$ unnormalizable states!), $\Delta x=0$, indeed, but $\Delta p=\infty$, to satisfy Robertson's formal inequality. You are effectively pleading for a formal way to bypass your technical mistake ("you get"; no you don't!). Take $\hbar=1$ w.l.o.g.
For starters, remind yourself of the identity $$ \epsilon \delta(\epsilon)=0, ~~~~\leadsto \\ \epsilon \partial_\epsilon \delta(\epsilon)= -\delta(\epsilon). $$
You are effectively considering matrix elements implicitly under the final step operation $\lim_{\epsilon \to 0}$. Specifically, evaluating the canonical commutator, $$ \langle x+\epsilon|[\hat x, \hat p]|x\rangle = i\delta (\epsilon), $$ divergent.
The same follows from your formal pathway, $$ \langle x+\epsilon|[\hat x, \hat p]|x\rangle =(x+\epsilon)\langle x+\epsilon| \hat p |x\rangle - x \langle x+\epsilon| \hat p |x\rangle=\epsilon \langle x+\epsilon| \hat p |x\rangle\\ =-i\epsilon \int \!\! dy~~ \langle x+\epsilon|y\rangle \partial _y \langle y|x\rangle= -i\epsilon \partial_\epsilon \delta (\epsilon)= i\delta(\epsilon), $$ by dint of $\hat p=-i \int \!\! dy~~ |y\rangle \partial _y \langle y|$.
So, taking the limit, you indeed find a divergent $$ \Delta x \Delta p \geq \delta (0)/2~ . $$
(You can take a further derivative in the leading identity, $\partial_\epsilon^2\delta (\epsilon) = {2\over \epsilon^2} \delta (\epsilon)$.)
Cosmas Zachos
  • 67,623
