Entropy has the units $J\cdot K^{-1}$. Velocity has the units $m \cdot s^{-1}$. In the latter example, I know what the units are quantifying across all applications of the quantity of velocity. Velocity as a quantity is applied to a body, and thus the meters quantifies the distance travelled by the body, and the seconds quantify the time it took for the object to travel that distance.
For entropy however, I do not know how to fully do this. Entropy is a quantity that is applied to the state of a thermodynamic system (I think). Thusly, I assume the Kelvins quantify the average kinetic movement of the particles within (the temperature of) the thermodynamic system in-question. But what about the Joules? They quantify energy, but the energy of what?
I suspect that with entropy, the Joules are quantifying the energy transmission between the system and its surroundings. Likely, I think the Joules are specifically quantifying the heat exchanged between the system and its surroundings. At max entropy, all of the energy accessible from the system at any moment (as quantified by Kelvins) is being transmitted as heat by the system to its surroundings. At minimum entropy, as much as possible of the accessible energy accessible from the system is being transmitted to the surroundings via non-heat, like electricity or mechanical work. If something like this interpretation is correct, it would explain a lot of the descriptions of entropy, like unuseful energy and disorder.
Basically, I am asking what the units of entropy are quantifying. I know they quantify energy and temperature respectively, but the question is; the energy and temperature of what?
