A recent arXiv paper by Capozziello et al (27 Feb 2023) claims:
the H0 tension is not due to neither systematic errors, nor to some new physics beyond the $\Lambda$CDM model, but simply to the fact that, in measuring the same quantity at different redshift, different results arise thanks to the look-back time evaluated at different epochs.
Now, maybe the solution is really this "simple", and I might be missing something, but I thought the age of the universe/lookback times depend on input cosmological parameters, including the Hubble parameter, i.e., just the redshift isn’t enough. I am noting this paper claims the age of the universe by Planck collaboration was derived without using $H_0$ via six independent parameters.
How can the Capozziello et al claim stack up?
It would seem to me to be a reheated version of this claim by the same author.
Mr Anderson
  • 1,494
Their equation (5) says
$$T_{lt} = T_0 − T(z) = T_0 − a(t)T_0$$
where $T_{lt}$ is the light travel time and $T_0$ is the present age of the universe. That implies they're assuming $T=a\,T_0$. In a footnote they say
The parametrization $T(z) = a(t)T_0$ is assumed as a label for the age of the Universe at a given redshift.
Fine, but you can't do that and also equate $T$ with the cosmological time, which they do.
They could be equated in a Milne cosmology, where $a\propto t$. It may be true that Milne cosmology is a better fit to this data, but Milne cosmology requires either $Ω\approx 0$, which is strongly excluded by other data, or general relativity being wrong. The paper claims to resolve the tension within the standard ΛCDM model, so it's just wrong.
benrg
  • 29,129
While benrg would seem to be on the right track with the answer, just after this question was posted, there seems to have been professional interest as well, such that a Comment on: paper was put up on arXiv by Escamilla-Rivera et al (3rd March 2023). The comment papers two main conclusions, respectively:
The lookback approach...cannot address the $H_0$ tension completely. Recovering the values from current collaborations under this approach does not correspond to an answer on why such an issue could be associated with $z$ measurements; and
The circularity problem is not avoided entirely, since the age of the Universe is sensitive to both $\Omega_m$ and $H_0$ for a flat $\Lambda$CDM cosmology. However, the local determination of H0 is not sensitive to $\Omega_m$.
The comment on paper has now been withdrawn, so obviously something wrong. However, since most of the citations on Capozziello paper are self-citations by the authors, and nobody seems to be taking any notice of it, benrg is no doubt correct in any case.
Mr Anderson
  • 1,494
Look back time also known as light-travel distance isn't well defined, so it doesn't make sense to use it for astronomical calculations.
For more information please see Edward Wright's Article https://astro.ucla.edu/~wright/Dltt_is_Dumb.html I can't see these points discussed in the reference you show.
timm
  • 1,607
