If, on the one hand, I were to paraphrase Gleason's theorem, it would loosely state that
if one can assign a truth value $p_k$ to each basis vector $\vec{u}_k$ such that $\sum_k p_k = 1$, then that assignment can only be produced by Born's rule using a density matrix $\hat{\rho}$.
while, on the other hand, Kochen-Specker states that
on the (3D) sphere, it is impossible to assign a truth value to each point among triples of points arising from orthogonal bases in such a way that those truth values behave as probabilities (namely, add up to one).
Based on the above, am I therefore to conclude that the link between Gleason and Kochen-Specker is that Kochen-Specker can only be violated by the Born's rule, i.e., by quantum mechanical assignments of truth values?
Please note: I don't have enough literacy in advanced algebra, so please keep the discussion intuitive and accessible to, say, a senior undergraduate, preferably starting from my (hopefully correct?) understanding of the theorems as I've stated them above. (This answer, for example, is currently beyond my grasp.)
Tfovid
  • 1,425
  • A direct consequence of Gleason's theorem is that when the Hilbert space $H$ has dimension at least three then there does not exist a value (aka frame) function $v$ that assigns only the values $0$ or $1$ to projections: $P:H\to H\,.$ Loosely speaking this means that it is not possible to assign true or false values to all elements of the Hilbert space that represent yes/no events (projections) in such a way that is compatible with their Boolean properties: e.g. $v(P_1+P_2)=v(P_1)+v(P_2)$ for $P_1\bot P_2\,.$
  • The Kochen-Specker theorem is similar in spirit. For simplicity I reproduce only the case $\dim(H)=4$ here: There exist $18$ projections $P_1,...,P_{18}$ from which one can form $9$ bases of $H\,,$ \begin{align} \{P_1,P_2,P_3,P_4\}\,,\dots\,,\{P_{15},P_{16},P_{17},P_{18}\} \end{align} such that it is not possible to assign the values $\{0,1\}$ to the projections so that in each of those bases exactly one projection has value $1\,.$ (Each projection occurs in exactly two of the $9$ bases.) This theorem rules out a value function that is independent of the chosen measurement basis.
  • Both theorems rule out non contextual hidden variables. I am not sure if your understanding of the Kochen-Specker theorem is correct. It deals with $\{0,1\}$-valuation, not just with summing to one.
A generalization of the Kochen-Specker theorem in $\dim(H)=3$ that looks fairly accessible you can find in
Voráček, V., Navara, M. Generalised Kochen–Specker Theorem in Three Dimensions. Found Phys 51, 67 (2021).
https://doi.org/10.1007/s10701-021-00476-3
https://link.springer.com/article/10.1007/s10701-021-00476-3
Kurt G.
  • 2,003
