Why is it assumed that the symmetry transformations change either the state $\psi$ or the operator $O$ but not both simultaneously? For example, if you assume $\psi\to T\psi$, you take $O\to O$ and if you assume $\psi\to \psi$, you take $O\to T^{-1}OT$. What is the logic here? This bit is not explained in the textbooks I am using (Griffiths and Shankar).
You have exactly the same situation with time evolution. In Schrödinger picture of quantum mechanics, the state of the system is assumed to evolve according to $$i\hbar{d\over dt}|\psi(t)\rangle=\hat H|\psi(t)\rangle \ \Leftrightarrow\ |\psi(t)\rangle=e^{-i\hat Ht/\hbar}|\psi(0)\rangle$$ while operators $\hat O$ are time-independent. Averages evolve according to $$\langle O(t)\rangle=\langle\psi(t)|\hat O|\psi(t)\rangle =\langle\psi(0)|e^{i\hat Ht/\hbar}\hat Oe^{-i\hat Ht/\hbar}|\psi(0)\rangle$$ You see that you could obtain the same expression of $\langle O(t)\rangle$ by assuming that the state is time-independent, i.e. $|\psi(t)\rangle=|\psi(0)\rangle$, but the operators evolve according to $$\hat O(t)=e^{i\hat Ht/\hbar}\hat Oe^{-i\hat Ht/\hbar} \ \Leftrightarrow\ i\hbar{d\over dt}\hat O(t)=[\hat H,\hat O(t)]$$ We have recovered Heisenberg picture of QM.
Time evolution is a special case of a transformation that can be applied to a quantum state. The general case is obtained by replacing $e^{-i\hat Ht/\hbar}$ by $\hat T$. Either you consider that the state is affected by the transformation as $|{\psi'}\rangle=\hat T|\psi\rangle$ and you assume that operators are not or you consider that the state is invariant but then operators should transform as $\hat O'=\hat T^+\hat O\hat T$ in such a way that the expression of averages $$\langle O'\rangle=\langle\psi'|\hat O|\psi'\rangle =\langle\psi|\hat O'|\psi\rangle =\langle\psi|\hat T^+\hat O\hat T|\psi\rangle$$ is recovered. Note that the average $\langle O'\rangle$ after transformation is not equal to $\langle O\rangle$. We just assumed that the two pictures give the same answer.
- 3,818
