According to quantum mechanics, there is fantastically (astonishingly, astronomically, infinitesimally, ridiculously etc.) small probability for a book on a table to quantum tunnel through the table.
Of course, such a claim is effectively untestable. However, it raises a question.
If one holds that it is real physical possibility.... then how is that different from someone who claims that human height follows a normal distribution and then holds that "it is possible a human will be born who will be 100m in height".
Iv Nik
  • 77
Technically speaking, quantum mechanics is a probabilistic theory of physics. It does not dictate the future state of a system with complete certainty, rather it states the probability of it being in different states.
Now, in some cases, the probability is $1$, which signifies a sure event. And probability $0$ indicates an impossible event. This is how the mathematical tools get a physical interpretation.
If I now have to quantify that for the $2$ instances you mentioned above, a person having $100\,\mathrm{m}$ height is surely a possible event, since the hypothesis suggests that human height follows a normal distribution. But the number of random and unbiased samples that need to tested to observe one such result will be huge. If you argue that the total human population count since the last $1000$ years shows no such instance of a human being over $100\,\mathrm{m}$ high, and that number should be enough to yield an occurrence of $1$ or $2$ such people at least, as per the expectation values calculated from the proposed distribution, then the answer is: the hypothesis is wrong. Human height follows a different distribution, or is statistically probabilistic and random.
Similarly, the probability of an electron tunneling through a table is very low and depends on the thickness of the table. Assuming a thickness of $2\,\mathrm{cm}$ for the table, using results of the rectangular potential barrier problem, the transmission probability comes out to be $<0.001 \%$. Combine that with the number of atoms the book has, and you will have a sample size comparable to the number of atoms in the universe, which will make this an "extremely rare but mathematically still possible" event.
