I have read that the electron spin is represented by a vector of 2 complex numbers. And a frequently asked question is how can it be that an electron must be rotated 720 degrees to return to its original state. I have read various posts and I am not satisfied with the answers given.
From what I gather in the mathematics there is a spin operator and when applied with 360 degrees the vector of 2 complex numbers is not the original.
But how does one "rotate" an electron as such? Can you apply a magnetic field that does that and only that operator?
And why should the operator by $n$ degrees count as rotating by $n$ degrees. I feel like all the explanations I read failed to justify the "rotation" or "spin" terminology. In comparison with quarks we speak of their color but we don't literally expect the property to behave like color and don't try to justify it. What I mean is if electron spin was called electron goomy then I wouldn't have a problem with the 720 degrees because goomy has no preconceived notion of what it should be. Why should we call the vector of 2 complex numbers spin instead of inventing a completely new term?
