I am studying the fine structure of the hydrogen atom. The non relativistic Hamiltonian of the Hydrogen atom is given by $$\hat{H}_{\mathrm{non-rel}}=\frac{\hat{\textbf{P}}^{2}}{2m_{e}}-\frac{e^{2}}{4\pi\epsilon_{0}|\hat{\textbf{R}}|}$$ We can replace the non relativistic kinetic energy term with a first order expansion of the relativistic kinetic energy, doing so obtains the folowing the Hamiltonian \begin{align*} \hat{H}&=\frac{\hat{\textbf{P}}^{2}}{2m_{e}}-\frac{e^{2}}{4\pi\epsilon_{0}|\hat{\textbf{R}}|}-\frac{(\hat{\textbf{P}}^{2})^{2}}{8m_{e}^{3}c^{2}}\\&=\hat{H}_{\mathrm{non-rel}}+\hat{V} \end{align*} For $$\hat{V}=-\frac{(\hat{\textbf{P}}^{2})^{2}}{8m_{e}^{3}c^{2}}$$ Since the perturbation, $\hat{V}$, is spherically symmetric, it is possible to apply non degenerate perturbation theory to calculate the perturbed energy. In order to evaluate this perturbation I expressed the perturbation as follows \begin{equation} \hat{V}=-\frac{1}{2m_{e}c^{2}}\left(\hat{H}_{\mathrm{non-rel}}+\frac{e^{2}}{4\pi\epsilon_{0}|\hat{\textbf{R}}|}\right)^{2} \end{equation} As seen in Sakurai Modern quantum mechanics. The result is that we have a first order perturbation of $$\Delta_{nl}^{(1)}=\frac{(E_{n}^{(0)})^{2}}{2m_{e}c^{2}}\left(3-\frac{4n}{l+\frac{1}{2}}\right)$$ where $$E_{n}^{(0)}=-\frac{m_{e}}{2\hbar^{2}}\left(\frac{e^{2}}{4\pi\epsilon_{0}}\right)^{2}\frac{1}{n^{2}}$$ is the unperturbed energy. I have now read an alternative source [1], which suggests this derivation is not correct for $l=0$, since the operator $(\hat{\textbf{P}}^{2})^{2}$ is not Hermitian for $l=0$, however coincidentally this derivation provides the correct result for $l=0$. Therefore, my questions are:
  1. Why would $(\hat{\textbf{P}}^{2})^{2}$ by non Hermitian for $l=0$?
2.Why does this mean that my expression $\hat{V}=-\frac{1}{2m_{e}c^{2}}\left(\hat{H}_{\mathrm{non-rel}}+\frac{e^{2}}{4\pi\epsilon_{0}|\hat{\textbf{R}}|}\right)^{2} $ is invalid?
  1. The problem is that some of the boundary terms at $r=0$ when trying to show self-adjointness $$ \langle \psi_{n00}, p^4 \psi_{m00}\rangle = \langle p^4\psi_{n00},\psi_{m00}\rangle$$ do not disappear for the $\ell = 0$ hydrogen states. See this answer by ZeroTheHero for a similar issue with the mere $p_r$, the problem for $p_r^4$ is similar but more severe since it contains higher powers of $\frac{1}{r}$.
  2. Perturbation theory assumes the Hamiltonian is Hermitian. The results may be correct, but strictly speaking you cannot apply perturbation theory to something that's not Hermitian.
ACuriousMind
  • 132,081
