Let's say we have a spin-up electron near x=-10:
$$\psi_1 = |\uparrow\rangle\alpha(x_1)$$
$\alpha$ being the space part: a bump near x=-10. Similarly we have a second spin-down electron near x=+10:
$$\psi_2 = |\downarrow\rangle\beta(x_2)$$
What if we want to consider these noninteracting, unentangled electrons as a system? I understand that it must be antisymmetric, so it seems that we should get:
$$\psi_\textrm{total} = \frac{1}{\sqrt2}( |\uparrow\downarrow\rangle\alpha(x_1)\beta(x_2) - |\downarrow\uparrow\rangle\beta(x_1)\alpha(x_2))$$
Is this correct? Would it be wrong to use only one term according to QM formalism?
As far as notation is concerned, you have different options. Often, the spatial information is included in the state: $$ |\uparrow\rangle\alpha(x_1) \rightarrow |\alpha(x_1),\uparrow\rangle ~~~ \text{or}~\text{just} ~~~~ |x_1,\uparrow\rangle . $$ If you just write down the state in a formal way then one term is OK, with the tacit understanding that it is anti-symmetrized. However, when you use it in calculations, both terms are necessary. Then $$\psi_\textrm{total} = \frac{1}{\sqrt{2}} \left( |x_1,\uparrow\rangle |x_2,\downarrow\rangle -|x_2,\downarrow\rangle |x_1,\uparrow\rangle \right) . $$ Sometimes, people combine the kets of the two particles, as you did, but I think it is clearer to keep them separate.
flippiefanus
  • 16,824
