For infinity potential well we take the analogy with nucleus. Inside which proton and neutron are bound in principle, if it is an infinite potential well, so particle should not come outside the nucleus. But what happens at the time of nuclear decay or radioactivity at that time particle come outside either through alpha or beta or Gama decay. How this could we possible??
In the real world there is no "infinity". The nucleus is not an infinite potential well, you can extract stuff from the nucleus if you put in a large-but-still-finite amount of energy. This explains why alpha radiation can happen.
You could say the infinite square well is a "particle in a box", but that's still an idealized system because no real-world box has infinitely high walls.
Of course, the real reason why we study the infinite square well in elementary quantum mechanics courses is because it's easy to solve - it's the easiest exactly solvable system - and still illustrates all the quantum weirdness that one will encounter later in QM.
- 23,373
Neutrons and protons in a nucleus are bound via strong interactions (and to some extent also through weak interactions) with the binding energies much greater than the Coulomb interaction between the protons and electrons (or protons and protons in the nucleus itself.)
This is the reason why in the textbooks non-relativistic quantum mechanics one can
- consider the nucleus as a single charged particle when calculating atomic energy levels
- consider the nucleus as an infinite potential well as a rough approximation for the intra-nuclear exitations (see, e.g., "Fundamentals in nuclear physics" by Besdevant, Rich and Spiro.)
However, as the OP correctly points out, description of nuclear decay requires more complex models. The simplest description of alpha decay is the Gamow model with a potential that looks like this (taken from this page) - note how it resembles a square quantum well close to the center.
Note that alpha decay, beta decay and gamma decay are three very different types of processes. Thus, in gamma decay only electromagnetic radiation is emitted by the nucleus, so the infinite height of the barrier is not the problem - what is missing in the model of infinite quantum well is coupling to the electromagnetic field. (See this thread for more on gamma decay.)
- 68,984
