In the following paper (Dynamical Reduction Models by Bassi and Ghirardi), at the end of section 5.3, the following claim is made.
Consider a bijective(*) map on pure states (not necessarily unitary or even linear),
$$S_t |\psi \rangle \rightarrow |\psi (t) \rangle$$
such that a mixture of states $|\psi_i\rangle$ with weights $x_i$ evolves into a mixture of states $S_t|\psi_i\rangle$ with the same weights $x_i$. In particular, $$\sum_i x_i |\psi_i\rangle \langle \psi_i| \rightarrow \sum_i x_i S_t |\psi_i\rangle \langle \psi_i| S_t ^\dagger $$
Let us consider now, at the initial time $t=0$, two physically different ensembles $E(0)$ with states $|\psi_i \rangle$ and weights $x_i$ and $E'(0)$ with states $|\chi_i\rangle$ and weights $y_i$, which are equivalent, i.e. $\rho(0)= \sum_i x_i |\psi_i\rangle \langle \psi_i| = \sum_j y_j |\chi_j\rangle \langle \chi_j|$.
Then, if we assume that
$$\sum_i x_i S_t |\psi_i\rangle \langle \psi_i| S_t ^\dagger = \sum_j y_j S_t |\chi_j\rangle \langle \chi_j| S_t ^\dagger$$
That is, the map $S_t$ has a special property that it maps two ensembles with the equivalent corresponding density matrices to final two ensembles with equivalent corresponding density matrices.
Then according to an elusive theorem of Davies, $S_t$ is a Unitary map.
The problem is, the citation to this thoerem of Davies points to a 180 pages long textbook- E.B. Davies, Quantum Theory of Open Systems, Academic Press, London (1976). There is not even a mention of the page number or section of the book the theorem belongs to.
Does anyone know of a proof of this theorem?
The proof of this theorem will establish why nonlinear maps on states will ALWAYS lead to superluminal signalling.
EDIT: I found another paper, published in 2015, which has one co-author in common with the 2003 paper, which claims to prove the same result. But unfortunately, again, the crucial part of the proof is not provided, and is mentioned to be present in a 1991 reference which is inaccessble this time. A softcopy of this reference is not even behind a paywall, anywhere.
This is the reference that is said to contain the proof- "Ghirardi, G.C. and Grassi, R., Dynamical Reduction Models: some General Remarks, in Nuovi Problemi della Logica e della Filosofia della Scienza, D. Costantini et al. (eds), Editrice Clueb, Bologna. (1991)"
(*) See answer of @quantummechanic to see the necessity of assuming bijectivity.
