Starting from the reasoning that $\langle x|p \rangle=e^{\frac{ipx}{\hbar}}$, I understand why the momentum operator in position space is $-i\hbar \partial_{x}$. What I'm looking for is some sort of intuitive reasoning as to why $\langle x|p \rangle=e^{\frac{ipx}{\hbar}}$. I've only found this derived from the definition of the momentum operator in position space, but I'm looking to go the other way.
Asked
Active
Viewed 407 times
The intuitive reason is that the momentum vector is a plane wave in the coordinate basis and this follows from the uncertainty principle.
jelly ears
- 981
Let us first understand what $|x\rangle$ and $|p\rangle$ are. They are (by definition) eigenfunctions of operators $\widehat{x}$ and $\widehat{p}$ with eigenvalues $x$ and $p$, respectively. So the first of them is a certain $\delta$-function, and the second one is an exponent. So to calculate $\langle x | p\rangle$, you need to take the Hermitian conjugate of $|x\rangle$, multiply by $|p\rangle$, and integrate.
akhmeteli
- 27,962
