In canonical quantization the Dirac equation is a complex column matrix, while in path integral formulation it's Grassmann numbers.
Is there a formula to convert from complex matrix to Grassmann numbers and vice versa?
In canonical quantization the Dirac field is a column vector of operators that obey anticomutation relations such as $\{\psi,\psi^\dagger\}= \hbar \delta(x-y)$. Grassmann numbers are the classical limit of such operators that remain when we set $\hbar\to0$. The Dirac field is never a column vector of complex numbers, although we make use of such column vectors when expanding the field in terms of normal modes.
mike stone
  • 58,971
  • 53
  • 158
  1. To tie to OP's terminology, a 4D Dirac spinor $\psi$ is a $4\times 1$ column matrix where each component is a field.
  2. The components may be operator- and/or supernumber-valued depending on context.
  3. When considering an equation that is linear in $\psi$ (such as, e.g. the Dirac equation), it becomes agnostic to whether we treat $\psi$ as Grassmann-odd or Grassmann-even.
  4. $\psi$ is Grassmann-odd in an interacting fermionic theory.
  5. For more information, see e.g. this and this related Phys.SE posts.
