Let us consider a system composed of qubits, with subsystems $\mathcal{A}$ and $\mathcal{B}$. For any measurement, described by an Observable $O=O_{\mathcal{A}}\otimes I$ that can be viewed as putting a slit on the bloch-sphere representation, are there observables other than ones with eigenvalues $\pm1$ (apart from trivial 0)?
If you consider one qubit, indeed a measurement (in any basis) can be described by orthonormal states $|0_a\rangle$ and $|1_a\rangle$ and the corresponding observable $O_a=(+1)|0_a\rangle\langle 0_a|+ (-1)|1_a\rangle\langle 1_a|$. Also for 2 qubits, an observable $O_a\otimes I$ has the eigenvalues $\pm1$.
manuel459
  • 466
If you have a qubit then you have a 2-dimensional Hilbert space. This means that you cannot have more than 2 mutually orthogonal states. This means that if these are eigenstates of some observable then you can have at most 2 eigenvalues. So if the eigenvalues are $\pm 1$ then you do NOT have a further possibility of value 0 for that observable. (If you did then you would have a qutrit not a qubit).
The pair of eigenvalues can have any values. Just to make the point, here is a list of possibilities: $$ +1, -1 \\ 0, 1 \\ 0, 0 \\ -2.3435, 7.3438 $$ where in the third example I picked a degenerate case and in the fourth I picked a pair of random numbers. The eigenvalues you get depend on the observable you measure. This is no big deal. It is like one person choosing to measure a length $x$, and the next person introducing an observable $y$ which is defined by $$ y = 9.6873 x - 2.3435 $$ so when $x$ is 0 then $y$ will be $-2.3435$ and when $x$ is 1 then $y$ will be $7.3438$. The purpose of this example is simply to show that the values of eigenvalues can in principle be anything you like, depending on how the quantity you are measuring is defined. This has nothing to do with the qubit itself. All the qubit itself dictates is that you can have at most two eigenvalues for a given Hermitian operator.
Andrew Steane
  • 65,285
Observables can have arbitrary (real) eigenvalues. Any Hermitian operator is an observable (which is a tautological statement: an observable is defined as a Hermitian operator). This holds for arbitrary quantum systems, and thus in particular for many-qubit quantum systems (which are those of dimension $2^n$ for some $n\in\mathbb N$).
If you consider local observables on many-qubit systems, that is, for two-qubit systems, observables of the form $O\otimes I$ or $I\otimes O$, then the eigenvalues will always be (at least) double-degenerate. That's trivially because you can always find eigenvectors of $O\otimes I$ to be simple tensors, i.e. vectors of the form $u\otimes v$, and moreover $v$ can be chosen arbitrarily.
If you want a specific example, consider for example the one-qubit observable defined as $O=\pi |0\rangle\!\langle 0|+\frac{1}{\pi^e}|1\rangle\!\langle 1|$. This has eigenvalues different than $\pm1$.
glS
  • 15,488
  • 42
  • 114
