The volume excess of earth due to general relativity in comparison to euclidean space has been calculated to
$$ \Delta V = \frac{ G M \pi R^2}{5 c^2} = 113 km^3 $$
(this is done in this physics.stackexchange.com - question:How much does the curvature of space change the volume of Earth by?)
That means $\Delta V$ increases linearily with $M$. Now, I'm wondering whether this is valid in general or only regarding the earth? Is that ("$\Delta V$ increases linearily with $M$") an inference out of Einstein's field equations? Is it true for any metric?
That means ΔV increases linearly with M. Now, I'm wondering whether this is valid in general or only regarding the earth? Is that ("ΔV increases linearily with M") an inference out of Einstein's field equations? Is it true for any metric?
No, it depends on metric. In spherically symmetric spacetime the proper volume is defined as: \begin{equation} V_{prop}=4 \pi \int_{0}^{R} r^2~g_{rr}(r,\alpha)^{1/2} dr, ~~~~~~\alpha\equiv r_{S}/R=(2GM/c^2)/R). \end{equation} For example, in case of constant density sphere (interior Schwarzschild solution) with metric component $$g_{rr}=\frac{1}{1-\alpha/R^2~r^2} $$ the proper volume results in \begin{equation} V_{prop}=V_{flat}~\frac{3}{2}~\Bigg[\frac{\arcsin{\sqrt{\alpha}}-\sqrt{\alpha (1-\alpha)}}{\alpha^{3/2}}\Bigg]. \end{equation} Only for $\alpha\ll 1$ the proper volume is proportional to $\alpha$ and thus to $M$: $V_{prop}= V_{flat}\cdot 3/10\cdot\alpha~\propto~M$.
JanG
  • 2,237
