This question is about expressions of the form $$ \langle x_f, t_i | \hat{x}(t) | x_i, t_i \rangle = \frac{1}{N} \int_{x(t_i) = x_i}^{x(t_f) = x_f} \mathcal{D} x~x(t)e^{i S[x]}. $$
In the following the states and operators are meant to be understood in the Heisenberg picture. I know how to arrive at the rhs of the equation: Putting an identity into the lhs: $$ \langle x_f, t_i | \hat{x}(t) \int dx |x, t \rangle \langle x,t | | x_i, t_i \rangle \\ = \int dx \langle x_f, t_i |x, t \rangle x \langle x, t | x_i, t_i \rangle \\ = \int dx K(x_f, t_f, x, t) x K(x, t, x_i, t_i) \\ = \int dx \frac{1}{N_f} \int_{x(t) = x}^{x(t_f) = x_f} \mathcal{D} x e^{i S[x]} x \frac{1}{N_i} \int_{x(t_i) = x_i}^{x(t) = x} \mathcal{D} x ~ x(t)e^{i S[x]} \\ = \frac{1}{N} \int_{x(t_i) = x_i}^{x(t_f) = x_f} \mathcal{D} x x(t)e^{i S[x]}. $$
What is the meaning of this object? Can this be thought of an "expectation value" of some sort?
Of course, the argument is somewhat clear (as also mentioned in this question:For a given $x$, $x_i$ and $x_f$ you get (by $K(x_f, t_f, x, t)$ the probability-AMPLITUDE that a particle that was at $x_i$ at time $t_i$ will be at $x$ at time $t$, and with $K(x, t, x_i, t_i)$ the probability-amplitude that a particle starting at $x$ at time $t$ will be found at $x_f$ at time $t_f$.
So if you definitely know that the particle started at $x_f$ and ended at $t_f$ then the product of both yields the Amplitude by which the particle was at $x$ at time t. Integrating over all x might then give you what is widely called "expectation value" - except for some difficulties (that the cited question sadly doesn't resolve):
  • For the expectation value interpretation to hold, wouldn't we need the probability (absolute square of $K * K$? )
  • Can we be sure that the result is real? I tried to take the complex conjugate, but in order to proof that it will be the same result, I need to make additional assumptions on $K$
  • Usually expectation values are taken between the same states, but even between same states, we still have problems with expression not neccessarily being real.
Quantumwhisp
  • 7,095
