I often heard that the eigenfunctions of a Hermitian operator form a completeness basis, as $$ \sum_i | i \rangle \langle i | = \hat{1} \tag{1} $$
and the mathematical foundation is the spectral theorem. The spectral theorem is $$ \hat{A} = \int \lambda dE_{\lambda}, \hspace{3cm} (2) $$ which in physicists' notation is (assuming discreteness) $$ \hat{A} = \sum_a a | a\rangle \langle a| \hspace{3cm} (3) $$
My question is: Eq. (1) is for a unit operator, which can be inserted anywhere. Eqs. (2) and (3) are for the operator $\hat{A}$, which is not a unit operator. How to transform (2) and (3) into the form (1)? Does it require some kind of scaling? (is that the projection-valued measure?) Perhaps such scaling is possible for a bounded operator and requires a more dedicated proof for an unbounded operator.
DanielC
  • 4,497
  • 25
  • 39
Gladeck
  • 83
The spectral theorem is that, if $A: D(A) \to {\cal H}$ is a selfadjoint operator, where $D(A) \subset {\cal H}$ is a dense subspace, then there exists a unique projector-valued measure $P^{(A)}$ on the Borel sets of $\mathbb{R}$ such that $$A = \int_{\mathbb R} \lambda dP^{(A)}(\lambda)\:.$$ As a consequence (this is a corollary or a definition depending on the procedure) $$f(A) = \int_{\mathbb R} f(\lambda) dP^{(A)}(\lambda) \tag{1}$$ for every $f: {\mathbb R} \to {\mathbb C}$ Borel measurable. Taking $f(x) =1$ for all $x\in {\mathbb R}$ we have $$I = \int_{\mathbb R} dP^{(A)}(\lambda)\:.$$ For selfadjoint operators admitting a Hilbert basis of eingenvectors $\psi_{\lambda, d_\lambda}$, $\lambda \in \sigma_p(A)$ and $d_\lambda$ accounting for the dimension of the eigenspace with eigenvalue $\lambda$, the identity above reads (referring to the strong operator-topology) $$f(A) = \sum_{\lambda, d_\lambda} f(\lambda) |\psi_{\lambda, d_\lambda}\rangle\langle \psi_{\lambda, d_\lambda} |\:, \tag{2}$$ with the special case $$I = \sum_{\lambda, d_\lambda} |\psi_{\lambda, d_\lambda}\rangle\langle \psi_{\lambda, d_\lambda} |\:. \tag{3}$$ In summary Eqs.(1) and (2) are the central identities, Eq.(3) is just a special case.
Given an orthonormal complete basis $\{\psi_n\}_{n \in \mathbb N} \subset {\cal H}$, one can always define ad hoc a selfadjoint operator $A$ (with no physical meaning in general) to implement the identities above: $$A = \sum_{n \in \mathbb{N}} \lambda_n |\psi_{n}\rangle\langle \psi_{n} |$$ for a given arbitrary choice of real numbers $\lambda_n$. The domain of $A$ is $$\left\{\psi \in {\cal H} \: \left| \: \sum_{n} |\lambda_n|^2 |\langle \psi_n| \psi \rangle|^2 < +\infty\right. \right\}$$
