Imagine I have a two-level quantum system $Q$ (motivating example: a trapped-ion qubit) where there is some energy difference between the states $\vert 0\rangle_Q$ and $\vert 1\rangle_Q$. Suppose I can drive it between the two states with a laser, where it transitions by either emitting or absorbing a photon.
If I send a number state of photons and measure it in the number state after it interacts with the qubit, this totally decoheres the qubit, since the environment/experimenter learns whether the number of photons was gained or lost.
So to actually drive the qubit we use a laser. A coherent laser state will have minimal entanglement with the qubit after this interaction, no matter what basis we measure it in. Basically this is the energy version of the momentum exchange in a beamsplitter, discussed here.
But if I tried to prepare a laser state from the vacuum state:
$$ \vert 0\rangle_L\mapsto \sum_{n=0}^\infty \frac{\alpha^{n/2}}{\sqrt{n!}}\vert n\rangle_L$$
(ignoring normalization) then this process clearly violates conservation of energy. The energy to send $n$ photons must come from somewhere: the laser source. So the laser beam will actually be in a state
$$ \sum_{n=0}^\infty \frac{\alpha^{n/2}}{\sqrt{n!}}\vert \psi_{-n}\rangle_S\vert n\rangle_L$$
where $\vert\psi_{-n}\rangle_S$ is the state of the laser source $S$ after giving $n$ quanta of energy to the laser mode $L$ (this paper discusses why this gives the usual mixed state representation of laser light; see also this question).
Because of the entanglement, if we measure both the laser source and the laser mode in the energy eigenbasis, we will once again completely decohere the qubit, unless the state $\vert \psi_{-n}\rangle$ was already in a coherent superposition of energy eigenstates.
But then we just keep pushing this argument back: where did the laser source get all this energy? From interaction with a different environmental system, which itself must have been in a coherent superposition. Conservation of energy continues to cause a problem: no system can spontaneously become such a superposition; we can only ever get a superposition of energy eigenstates in one system if it's entangled with another system that gained/lost the same amount of energy.
We could also avoid decoherence if we just measure the laser source and the laser mode in some basis that is not energy eigenstates. However: statistical quantum mechanics seems to postulate that quantum systems will tend to thermal equilibrium, which puts them in the Gibbs state. The Gibbs state is a mixture of energy eigenstates. In other words, this postulate means that thermalizing with the environment is effectively a perfect measurement in the energy eigenbasis.
But this would imply that once we drive this qubit transition, eventually the environment will cause it to decohere, no matter how well we isolate the qubit itself. Experimentally, this seems to be false: trapped ion quantum computers where everything but the ion is at room temperature can maintain coherent superposition for minutes or longer.
This seems to mean that actually, everyday classical systems are not in the Gibbs state, but must have some superposition of energy. I haven't found anything that describes such a state, though!
Can anyone provide/reference such a description, or point out where my reasoning has gone wrong?
Sam Jaques
  • 1,397
Gibbs states are equilibrium states that are also stable under realistic measurement/decoherence, but we are talking about a highly non-equilibrium setting. What is the most common non-equilibrium state that is stable under decoherence? A coherent state!
However you don't need coherent states to make coherent states, and that's not how lasers make them. The short answer is that measurement in a basis that does not commute with photon number produces coherence between different energy states, and plenty of realistic measurements (like electric field) fit the bill.
Mommy, where do coherent states come from?
According to this answer and the textbook it cites, truly ideal lasers actually emit a classical mixture of Fock states (states of definite photon number). Unlike coherent states with their well-defined phases, this mixed state is rotationally symmetric and does not have any coherence. Hence the mystery.
You can understand a lot of the physics of a laser by considering a charged mass on a spring. If the mass is displaced from the origin (i.e. it is initialized in a coherent state), then the resulting oscillating charge will radiate a coherent state. No surprises so far. You want to understand how we can get a coherent state when the mass starts in a state of definite energy, i.e. a Fock state*. In the phase space of the oscillator, this Fock state looks like a ring, and this ring contracts toward the origin as the system radiates. If the initial excitation number $N_0$ is large, then the probability distribution of emitted photons is Poissonian, just like a coherent state. The joint state of the oscillator + radiation is the entangled state
$$e^{-|\alpha(t)|^2/2}\sum_n \frac{\alpha(t)^{n}}{\sqrt{n!}} |N_0 - n\rangle |n\rangle$$
just like in the statement of your question. These entangled 'rings' are highly non-classical. Specifically, they are highly unstable to realistic measurement and decoherence. To see what happens under various measurements, consider writing the density matrix for the light mode in two different ways
$$\rho_\text{light} \propto \sum_n \frac{\alpha^{2n}}{n!} |n\rangle\langle n| \propto \int_0^{2\pi} |\alpha e^{i\phi}\rangle\langle\alpha e^{i\phi}|d\phi$$
Observers measuring energy ($n$) won't disturb the state too much, because the $n$ distribution $\alpha^{2n}/n!$ is sharply peaked around $n=|\alpha|^2$. However even a very course measurement of electric field will distinguish between $|+\alpha\rangle$ and $|-\alpha\rangle$ if $\alpha$ is large!** For instance, if we measure the electric field of the radiation by placing a very light charge and measuring its velocity at a later time, the mass will move up or down depending on the measurement outcome.*** In short, electric field measurements, which create superposition between different $|n\rangle$ states, cannot be ignored macroscopically. Note that this argument doesn't apply to thermal states, because they don't contain macroscopically different values of $E$ (and therefore an imprecise measurement of $E$ leaves a Gibbs state unchanged).
For a broader context, states that are stable under decoherence are referred to as pointer states, which are discussed in the context of quantum Darwinism. At high frequencies, where you can't play the trick of measuring the electric field with a point mass, some have argued that coherent states actually don't exist in practice, but are rather merely a 'convenient fiction.' See this paper.
*Initializing in a Fock state is somewhat analogous to having population inversion in a real laser. Things still work out of you prepare a mixture of Fock states, as long as the variance isn't too large. Initializing in a thermal state won't do, because then we will just emit thermal radiation!
**In fact the highly unstable state $|\alpha\rangle + |-\alpha\rangle$ is called a cat states, in reference to Schrodinger's cat.
***This resolves the apparent paradox in your original question. Qubits made of atoms are essentially electric or magnetic field sensors, because they couple to the electromagnetic field via $(a+a^\dagger)\sigma_x$. Thus if we interact a bunch of qubits with a 'ring state,' the ensemble has effectively measured the electric field and collapsed it onto a coherent state. Upon observation of the whole system, the physics will be basically consistent with it having been in a coherent state to begin with.
user34722
  • 3,303
Short answer, but you said it yourself. If the laser is in a coherent state then, because of the unique properties of the coherent state, it is NOT entangled with the qubit after interacting with the qubit. As you say, the laser must become entangled with the environment during the turning on of the laser. But since the laser/qubit interaction doesn’t result in entanglement the qubit is not entangled with the environment so there are no loss of coherence concerns.
Well, there’s more to say. You stipulate that if we measure the environment in the energy eigenbasis we will decohere the qubit. Yes this is true. But we don’t typically measure the environment in the energy eigenbasis. One way to think of it is this. When you use a laser to put a qubit in a coherent superposition case it is actually the case the whole room is in a crazy superposition state of having one more or less quanta. But the room basically looks the same in either case. That single quanta is distributed among trillions of trillions of degrees of freedom. It would require an unthinkably precise measurement/interaction to observe the difference between the two situations. Can try to say more to clarify later.
Sorry this is going to be more rambling than an answer.. but also, a laser is an out-of-equilibrium system. So you can't apply stuff like "However: statistical quantum mechanics seems to postulate that quantum systems will tend to thermal equilibrium, which puts them in the Gibbs state.".
Jagerber48
  • 16,234
The laser is in a coherent state. If the intensity of the laser corresponds to average of $n$ photons, the state will have fluctuations in that number that go like $\sqrt{n}$.
If $n$ is large enough, the fluctuations completely overwhelm the 1 photon that may have been absorbed by the qubit. In other words, there is fundamentally no way to derive any information about the state of the qubit by measuring the coherent state before and after it has interacted with the qubit. Therefore, since no information can be extracted, no decoherence is necessary.
That's why we want to couple the qubit very weakly to the control drive (laser or microwaves): weak coupling means that we need many photons in the coherent field needed to affect a pi pulse, which means the fluctuations will be large, and therefore the control drive cannot be used to extract information.
To answer your question "what about conservation of energy" more directly - if someone was to keep track meticulously of all energy quanta, they could not, even in principle, notice that you skimmed off one photon from the laser to excite the qubit.
