Let's consider the Feynman diagram of a propagator of a particle. Is it considered as a one leg diagram or a two legs diagram?
Is it considered as an interaction? (I would think that an interaction means that a particle interacts with another particle, so that one needs at least 3 legs)
Do interaction with 2 legs (or one leg) exist in Standard Model?
One and two leg diagrams are not interactions, as pointed out by Felicia in the comments.
A one leg diagram corresponds to a "tadpole", which have to vanish for stability reasons. Physically, these diagrams would correspond to processes where particles just pop out of the vacuum, and therefore if they didn't vanish they would imply that the vacuum is unstable. Mathematically, these diagrams vanish when the background fields satisfy the classical equations of motion. For instance, in the standard model, tadpole terms involving the Higgs vanish when the Higgs VEV is at a minimum of the potential.
A two leg diagram is a propagator, which is not an interaction -- one particle goes on, one goes out.
Interactions are described by vertices with three or more particles.
Andrew
  • 58,167
To perform perturbation theory, the action $$S~=~S_{\rm free}+S_{\rm int}$$ is split into a free and an interaction part. The free part$^1$ $$S_{\rm free}~=~\frac{1}{2}S^{\rm free}_{k\ell}\phi^k\phi^{\ell}$$ is always quadratic and non-degenerate in the fields $\phi^k$. The inverse matrix $(S_{\rm free}^{-1})^{k\ell}$ is the free propagator, cf. e.g. this Phys.SE post.
  1. An action term linear in the fields produces diagrammatically a 1-vertex (1 leg). It is either a tadpole or a source.
  2. An action term quadratic in the fields may be assigned$^2$ to the free or the interaction part, depending on application. If it belongs to the interaction part it produces diagrammatically a 2-vertex (2 legs). Typical examples are counterterms for wavefunction renormalization or mass-renormalization. This e.g. applies to the standard model.
$^1$ We use DeWitt condensed notation to not clutter the notation.
$^2$ Note that the free part should be non-degenerate, so one can not assign all quadratic action terms to belong to the interaction part.
